01-14-2011, 14:18 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Unable to Repair IMEI in Voice V41 !! Its New firmware Code: New firmware found (v.3.26, database date: 23.12.2010): DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L201_ET.BIN Tried Safe format, Full Format, Imei Mode 1, mode 2 & Mode 3 Also Default IMEI inside firmware, But Even Though it says Success, when Checked at Handset or at General info, Same.. Code: Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: DEWAV25_GEMINI_HW Software version: T68D_V41_L201_ET" Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: #98999+9" imei-2: #98999+9" imei-3: #98999+9" Finished, time used: 3 sec Remove/Install battery now ! Any Urgent Help will be Helpfull! Thanks |
01-15-2011, 08:46 | #4 (permalink) | |
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Quote:
Here is Mode - 1 Log Code: Imei 35------------ already was repaired: 14/Jan/2011-6:58:25 PM Continue with this imei ? Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: #98999+9" imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 35------------ verification Ok Finished, time used: 5 sec Remove/Install battery now ! Here is the log for default IMEI inside firmware Code: COM3 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 35------------- ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:A203:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.26, database date: 23.12.2010): DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L201_ET.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L201_ET.BIN project-id: T68D_V41_L201_ET, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... .......................... ffs/eeprom: detect std location pass #1... .................................................... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 35------------- Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000001:18E59F00000000 flash: 98000300000001:18E59F00000000 Write: imei Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 1 min 59 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
01-15-2011, 09:49 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Try with option "AutoDetect 6253 NOR" in Model tab. I found it in one phone and after choosing this option it succeeded. So you can try out. Wr. |
01-15-2011, 12:08 | #6 (permalink) |
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Thanks lot mate for the reply, But It doesn't worked for me!! Log Code: Action: "repair imei" Model: Autodetect 6253 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: #98999+9" imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 35------------ verification Ok Finished, time used: 4 sec Remove/Install battery now ! |
01-16-2011, 21:28 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make full backup and try following flash file: flashfiles/ChineseMiracle/_MT6225/DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L200 _ET_16m_En.B0M.bin |
08-13-2011, 11:45 | #10 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1188586 Status: Offline Thanks Meter: 0 | voice v41 imei not repair,how can with details startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L201 _ET__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\DEWAV25_GEMINI_PC B01_GPRS_MT6225_S00.T68D_V41_L201_ET__ffs_20110813-160631.B0E.bin flash: 98004900000002:18E59F00000000 Backup required data Done ====> Patch required data ... 4 step(s) required Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98004900000002:7B717A00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 12 sec Remove/Install battery now ! |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
