Old 11-18-2008, 19:49   #1 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Vento FW Pls.. (E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1)
hi all and supporters..
anyone has this phone..? i need fullbackup.. eeprom and flsah file...
ver. sw1: E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E551_C7TURKBT2.01.1, 1D5F52DE
COM14 [VCP2] selected
module v2.66
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:AE9C:BBD9
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.53273641.[E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1.BIN_21ADA0E2].rpl
New firmware detected (2.66) :
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 53273641
identification#1 protocol ver: 04
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
Do you want to use standard eeprom address: 00800000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\system_log_53273641_E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1.BIN_21ADA0E2_20081118-130410.B0X.bin
Finished, time used: 198 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 11-18-2008, 20:06   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what problem with phone? did you try to solve it by formating FFS (safe or complete)?
we dont have exactly same version in our collection, but have similar.
for example: flashfiles/ChineseMiracle/_MT6226/E551_C7TURKBT3_E551_GPRS_MT6226_S01.01_1__ITEL_IT7 00_16m_En_Tr.B0M.bin
worth to try them, but only after you backup your existing version (read full flash operation)
other similar file you can find making search in support area, keywords is "E551_"
here is example how to use support area search option:
http://forum.gsmhosting.com/vbb/showthread.php?t=499453
Old 11-18-2008, 20:18   #3 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hello!
thanx sir.. i really checked th support page..but i searched the "E551_C7TURKBT2".. and no result.. i didnt really searched "E551_".. but i think this flash file will work.. i will try and post result.. after ffs format phone is dead..and i havent backup eeprom..i checked the chinese miracle directory..
Old 11-19-2008, 22:28   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hello!
hi again...
phone worked with this fw again.. "E551_C7TURKBT3_E551_GPRS_MT6226_S01.01_1__ITEL_IT 700_16m_En_Tr.B0M.bin"
Pls help me to get V195 FW file readed by FB3 anhtam Motorola P2k 1 11-29-2006 23:49
W810 dead after flashing FW pls help Andy187 Cruiser Suite 10 11-15-2006 14:53
Upload D520 FW into support area, pls. kasner UST Pro II 13 05-19-2006 19:38
W900i dead when tryin to Flash Main FW!pls see the error!!! ReyTech Cruiser Suite 4 03-30-2006 16:56
6270...Flash,tools,fw?Need pls dj_markom Nokia Hardware & Hardware Repair 0 01-15-2006 09:43
Page generated in 0.17167 seconds with 9 queries
