Veptu 8088 pinout as intitled-i need pinout for veptu 8088 i tride to find in doccumentatation but can`t find THX in advance |
well,i`ve managed to find out the pinout,will post it later cause the phone is curently on box i`ve read the eeprom and full flash,also read the detailed information,and now ,after flashing the phone is dead. now returning the backupo and will see what happens this is my first encounter with chinese miracle models and sincerly i`m a little bit confused,even though the manuals is the flash file on the support area enough to repair a Veptu that didn`t show incoming calls? the backup file is 10,0 MB and the flash file is 8,5MB,is it ok? |
phone is alive again,after restoring the backup,but with the same problem-incoming calls are displayed only after call is ended any suggestions? thx in advance |
Software : 1.Try to find good flash file in support to write it. 2.Format phones (90% problem software can repair by format) Hardware In my opinion , 90% problem hardware of chinese miracle is CPU. you can check battery, reball CPU, dont care CPU can die. It's very strong. |
problem solved with formatting thx a lot but still-i would like to know how to sucessfully flash this phone,for other cases is the only way trying file after file? |
@Rhamses the only way: your experience and phone firmware/file name. btw, pls, post here pinout that you have found, it will be useful for other people. |
must appologize but sincerly i`ve forgot to write down and i`ve already gave the phone to the *******r i`ll try to remember it was a 8 pin connector keyboard ----------- \________/ 1......8 1-Charger 6-TX 7-RX 8-GND If this is wrong try inverting RX and TX sorry,my mistake for not writting it down earlier Greetings! |
this one is wrong mate gnd-1, tx-2, rx=3 tested and aproved by me by bicco |
COM7 [VCP4] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6219:8A01]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219,E01 Date: 2004.06.18 Version: 1.7.1.2 Version: M300.05.24.V18 Version: E01_HW detecting structure #2... done imei: 13579024681122 connection Ok detecting structure #1... error: detection failed, read flash and send to support Operation failed ! Finished, time used: 10 sec Remove/Install battery now ! why i cant unlock this phone NARNIA 8088 when i try to formate it format well all 2 way but phone problem is when u power it it works but after few minuts it ask u passowerd and a short time will power off it self |
Hi I have the solution you dont even need to flash it at all. just enter the codes will do to solve that problem. http://forum.gsmhosting.com/vbb/showthread.php?t=761092. that will solve all this problems. Hope this helps. |
