12-01-2009, 19:10 | #31 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | yes, GND is that one which gives Beep and show "0" when you measure test point against phone GND. it is better to solder this resistor back, it might be pull up resistor for Tx or Rx |
12-01-2009, 19:32 | #32 (permalink) |
Freak Poster Join Date: Sep 2009 Location: www.telefony-nawigacje.pl
Member: 1122479 Status: Offline Thanks Meter: 22 | hi i'm back and i solved my problem!!! the problem was with my crocodile cable which was changed in manufacture, red was black (+was-) so i can't connect phone |
12-01-2009, 20:33 | #33 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, we had this problem on part of our pinfinders. thanks to chinese guys on factory. this is why i always advice to try power On phone using pinfinder power and only after that continue by searching |
12-01-2009, 20:55 | #34 (permalink) |
Major Poster Join Date: Sep 2009
Member: 1123097 Status: Offline Thanks Meter: 5 | thanks much, i'll try to solder it on someway but it is VERY SMALL. I hope that i build a cable for flashing my phone soon. The battery has to be connected and power button pressed to find tx rx and gnd on PCB?? |
12-02-2009, 19:05 | #36 (permalink) | |
Member: 1123097 Status: Offline Thanks Meter: 5 | pinouts Quote:
1- not constant 2- 2.8v (starts at 2.789 then settles at 2.8) 3- 2.853v 4- 0.656v 5- 3.56v 6- 0v (GND) 7- 60.6v (YES, 60.6 VOLTS. That wasn't there before the resistor thing fell off) 8- 40.9v 9- 40.9v 10- not constant BEFORE the resistor fell off, i got these readings: 1- 2.815v 2- 2.839v 3- 2.846v 4- 3.310v 5- 3.346v 6- 0v (GND) 7, 8, 9, and 10- 0v. So after it fell off, does pin 1 matter anymore? Can i still flash it? | |
12-02-2009, 20:12 | #37 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think you must start from pins 2 & 3 connect box pin 8 to phone GND. box pin 2 to phone pin 2 box pin 3 to phone pin 3 attach battery and try to boot phone. if it will not boot- change with places (sawp) pin 2 & 3. you will get connect box pin 8 to phone GND. box pin 3 to phone pin 2 box pin 2 to phone pin 3 try to boot again |
12-02-2009, 20:22 | #38 (permalink) | |
Member: 1123097 Status: Offline Thanks Meter: 5 | Quote:
12-02-2009, 20:26 | #39 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! even if you dont have box you must use pins 2 & 3. but try them both ways if cannot connect |
02-04-2010, 05:03 | #41 (permalink) |
Member: 1123097 Status: Offline Thanks Meter: 5 | I got my flash cable from ipmart and change the connector. I have the corrects pins but both spiderman and flash tools say some error occured because it failed to load boot rom. Please help! |
Vertu Ascent Ti, RM 267v | freeman 2008 | Nokia Hardware & Hardware Repair | 7 | 01-13-2015 21:22 |
Chinese-Vertu Ascent Ti-RM-267v | asarmen | Chinese Models & Cloned Phones | 4 | 04-26-2010 09:54 |
Vertu Ascent-Ti-RM-267V EASY PINOUT here | jawad8305 | Infinity-Box | 1 | 03-12-2010 08:24 |
Chinese-Vertu Ascent Ti-RM-267v flash file | alexmkdMAFIA | Chinese Models & Cloned Phones | 2 | 12-20-2009 23:15 |
Vertu Ascent Ti, RM 267v | freeman 2008 | Various | 2 | 05-07-2009 22:10 |
