Old 02-04-2009, 10:26   #1 (permalink)
Headmade's Avatar
Member: 16899
Thanks Meter: 18
Very need flash file for 8600d
Hello to all.
Very need flash file for chines Nokia 8600d RM-164. Not power on at all. After format with complit mode, same thing. It is looks like original - high copy, has 5 pin connector, like original noka 8600 mini usb. MTK 6225. And firmware info readed by infinity is
ver. sw 1: LX686_06B_HW.Y686_QCIF_TH5_V4_9GTEST--080909.BIN
ver. sw 2: Y686_QCIF_TH5_V4.9GTEST, 00000000
Pinout is hidden under imei sticker
Can not find in support area, so please upload it, if you have.
Thnx.
Old 02-04-2009, 15:50   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
unfortunately, we dont have nothing even similar to this version.
to repair this phone you must find same version working set and use its backup
Old 02-04-2009, 17:00   #3 (permalink)
Headmade's Avatar
Member: 16899
Thanks Meter: 18
Here you can can download working file, but it is under flashtool. Please convert it under infinity, so infinity users can use it. http://www.gsmforum.ru/showthread.php?t=37605
Let me know and I will test it with infinity.
Thnx.
Old 02-04-2009, 19:59   #4 (permalink)
Member: 148515
http://rapidshare.com/files/19392170...m.B0E.bin.html
Old 02-05-2009, 08:24   #5 (permalink)
Headmade's Avatar
Member: 16899
Thanks Meter: 18
COM8 [VCP1] selected
module v2.74
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0603:000F
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE508009FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[LX686_06B_HW.Y686_QCIF_TH5_V4_9GTEST--080909.BIN]...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[LX686_06B_HW.Y686_QCIF_TH5_V4_9GTEST--080909.BIN]_20090205-104223.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 655 sec
Works, like a charm! 2 phones repaired, and they have RU corrected.
Thank you Infinity team.
Old 02-05-2009, 14:07   #6 (permalink)
Member: 148515
hello!
nice to know!
i will upload this flash file to our support server
!!!!! Needed, flash file for 8120 02 sfi file !!! stemo FuriousGold 2 03-11-2009 20:08
i need flash file for G8000 and how to flash it??? tsarkh VygisToolbox 2 08-08-2007 09:30
Very Need Flash Files For N77 stepanok Nokia Base Band 5 ( BB-5 ) 2 06-16-2007 11:14
need flash file for c65 any version 810d flash saeed-gsm SIEM Service Tools 2 12-27-2005 12:58
Need flash file for dejan 1.05 or full flash for 6250 with polish language Rafal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 08-10-2002 20:13
Page generated in 0.19804 seconds with 9 queries
