02-05-2009, 15:09 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | well no one can say what a CPU Type a chinese phone have in it unless u open it or make a reading from some ... but majorty of the phones are MT62XX based phones .... so the best thing is this that u dissamble phone and chek it out ... or pinfinder can help u also |
02-05-2009, 17:37 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you can either do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is mt62xx CPU based. If you dont see this- you must disassemble phone |
02-05-2009, 19:12 | #4 (permalink) | ||
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
Thks For Replay | ||
02-05-2009, 19:21 | #5 (permalink) |
Member: 322417 Status: Offline Thanks Meter: 940 | software version: 1.16 cable type: 1x5 (L5A) platform: MT: MT62xx (autodetect) searching adapter at COM8... adapter found, version: 2000 pins: 5, plain power cycles: 10 activation cycles: 20 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 162 sec Power Off ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") Can't Find Pin out does know what pin outs use this rm-17 n95 8gb Chinese ? regards |
02-05-2009, 19:49 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 8gb N95 unfortunately doesnt hold Tx/Rx in system connector. please try L4A connector in handsfree port. if you fail again- you must look for test points on PCB. we have PCB pictures in our pinout folder. but you must disassemble your phone to compare with them |
Chipnuts cpu what platform to select? | GSMaxx | SpiderMan | 0 | 12-09-2009 06:40 |
What Phone Model Select To Flash P260????? | dj_mseal | UST Pro II | 0 | 03-07-2009 22:23 |
How to find pinout for CPU SPD6600M with CPF II (video) | .::CPF-TEAM::. | CPF-BOX Ⅱ | 1 | 07-17-2008 20:32 |
can same one tell me abut mc_tool i conect in phone and i select auto finde pinout n | girumm | MC-Tool | 1 | 06-13-2008 08:26 |
