Old 03-07-2011, 13:56   #1 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
Why i got "wrong Cs" error everytime,when i read flash?
COM10 [Serial2] selected
module  v3.27
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:9888:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 2088C4FFFF0043:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2D0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
warning: wrong cs at 0x0001ACDC, retry...
read error recovered
warning: wrong cs at 0x000368DC, retry...
error: too many retries during read operation
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
New firmware found (v.3.27, database date: 20.11.2009):
GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 07
sw version: GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10.BIN
project-id: GD1101_V2_FDT_T32T3W0_DSIM_L3_V10, 00000000
code offset: 00000000
ffs offset/size [02]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
error: wrong answer: 4D
error: wrong answer: 00 : wrong answer after chip id request
error: wrong answer: FF : wrong answer after chip cfi request
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
aborted by user
operation aborted
Finished, time used: 45 sec
Remove/Install battery now !
i need to repair "no license to produce".
i am sure, cable connection is 100% ok. becaues in format i do not have any problem. problm occures only when i try to read flash.
Help me Supporters
Old 03-07-2011, 14:01   #2 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
module  v3.27
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 07
TCL-ID is absent
aborted by user
operation aborted
Help me Supporters
every time this problem come due to HARDWARE FAULT.
But try to read flash with low speed minimum speed.
if not work then try to change box port it must be under 10 comport
The Following User Says Thank You to alamgarh For This Useful Post:
Old 03-07-2011, 14:42   #3 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
does all phone have hardware problem?i tried it with many phones,
now trying with slow speed will post result.
Old 03-07-2011, 17:35   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
I suggest you to use another cable and see results.
Old 03-10-2011, 16:27   #5 (permalink)
Member: 1533686
If that still does not work,reinstall the flash player to try again.
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
Page generated in 0.16086 seconds with 9 queries
