03-28-2009, 21:27 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post full format LOG. there is alot of usefull information I hope you tried to keep power button pressed around 30seconds, and battery is full charged? i am asking, becuase this is most common mistakes |
03-30-2009, 16:27 | #3 (permalink) |
Freak Poster Join Date: Mar 2006 Location: morocco Age: 39
Member: 243158 Status: Offline Thanks Meter: 25 | COM5 [VCP0] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B18E7E32.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN_0 9B2A37C].rpl identification#1 detection finished device-id: B18E7E32 identification#1 protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN ver. sw 2: UPU25U26V03B09, 835C4DF6 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]_20090330-152506.B0E.bin flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B18E7E32_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B09.BIN_09B2A37C_20090330-152526.B0X.bin Finished, time used: 142 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Thanks in advance. |
03-30-2009, 20:41 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flash phone with firmware available on support area: [bin] flashfiles/ChineseMiracle/_MT6226/U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09_16m_E n_Fr_Ar.B0M.bin |
03-31-2009, 15:44 | #5 (permalink) |
Member: 243158 Status: Offline Thanks Meter: 25 | always the same problem phone not power on COM5 [VCP0] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B18E7E32.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN_0 9B2A37C].rpl identification#1 detection finished device-id: B18E7E32 identification#1 protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN ver. sw 2: UPU25U26V03B09, 835C4DF6 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]_20090331-143003.B0E.bin flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . detect device identification#2 finished security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B18E7E32_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B09.BIN_09B2A37C_20090331-143033.B0X.bin Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B18E7E32_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B09.BIN_09B2A37C_20090331-143834.B0X.bin Finished, time used: 653 sec Remove/Install battery now ! |
04-01-2009, 16:47 | #7 (permalink) |
Member: 243158 Status: Offline Thanks Meter: 25 | phone not power on I have the same problem COM5 [VCP2] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B18E7E32.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN_F 69250D5].rpl identification#1 detection finished device-id: B18E7E32 identification#1 protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN ver. sw 2: UPU25U26V03B09, 2AAF6D09 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B09.BIN]_20090401-125622.B0E.bin flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B18E7E32_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B09.BIN_F69250D5_20090401-125637.B0X.bin Finished, time used: 129 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-02-2009, 23:32 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! same working phone must be found in order to repair faulty. full backup taken from working phone must be used for flashing faulty one |
10-19-2009, 10:07 | #10 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | Quote:
could you please tell me how did you arrive to know that this is for TV8000? i am trying to fix some TV8000 all with white screen. These are my first ones with pin finder and am finding it very difficult to know which files to use. inside the phone there is this flash : R901_31MLT_PCB01_GPRS_MT6225_S00.M_RR9013102_M2810 2_V1_0_0_0M0815.BIN which is not in database but as i mentioned before its showing white screen. thanks for any help Last edited by Burnt Cobba; 10-19-2009 at 10:14. | |
10-19-2009, 11:41 | #12 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | another follow up. read the flash file from another TV8000 and reflashed this one. again white screen. I am suspecting this white screen problem is actually a hardware problem. Here are the details and flash file for those who require them. Hope at least they ll help someone. Yingtai TV8000 Full flash : http://rapidshare.com/files/29500014...120527.B0M.bin Eeprom : http://rapidshare.com/files/29500023...121051.B0E.bin |
6030 mobile not power on, on battery and working fine on power supply | kashif_khatri | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 09-19-2009 02:57 |
7370 power on on ufs but not power on battrey | dereje | Nokia Hardware & Hardware Repair | 0 | 05-26-2009 09:25 |
help 3310 in tornado it power on but with batterie it not power on | sofiame2006 | Nokia Hardware & Hardware Repair | 3 | 08-02-2005 08:46 |
G5600 not powers on with sim while without sim powers on :( need help | the_frightener | LG | 1 | 03-20-2005 06:18 |
t100 not power on after flash, not power on when original cable is plug | GYZMO | VLSI, Conexant, Skyworks and Old Models | 8 | 01-07-2004 00:34 |
