01-30-2009, 13:30 | #1 (permalink) |
Registered User Join Date: Aug 2004 Age: 44
Member: 76882 Status: Offline Thanks Meter: 56 | Z300 flash file z300 dead , read flash files is emty please check logs and tell me is it hardware or software probem? COM6 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:73C1A56 high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881600010001:89881600000000 flash: Intel B 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89881600010001:89881600000000 flash: Intel B 32Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin number of flash chip/regions detected: 01/01 total flash region size: 02000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 01000000 flash: 89881600010001:89881600000000 checking area [00000000]: 00000000-01FFFFFF... eeprom/ffs found near: 01600000 Detected eeprom/ffs address is non-standard: 01600000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 01600000 detecting eeprom/ffs size... eeprom/ffs size: 00A00000 ffs chip: 00 eeprom/ffs area: 00000000:01600000-01FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash... |
01-30-2009, 20:36 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, probably flash chip empty, erased, incorrectly flashed or damaged. Post here phone photo, probably somebody can give you an information what firmware should be used. Also you can check PCB, fins marks at PCB and try to find similar firmware in support area. |
z300 flash files | noi | Cruiser Suite | 8 | 02-21-2009 13:52 |
z300 flash file for hwk need | kasra | HWK | 2 | 09-17-2006 23:01 |
need K600 & Z300 flashe file | cooloxf | SonyEricsson (USB-Smart) | 4 | 08-27-2006 11:05 |
SE Z300 flash file needed.. | mobilesmith | Cruiser Suite | 7 | 07-06-2006 07:37 |
Z300 flash files needed... | Invader | Cruiser Suite | 1 | 05-22-2006 10:26 |
