Just wanna share that I succesfully repaired a rebooting ChineseMiracle ZH Model ZH6688..
Just selected a ZTC 6688
Pinout i used:
or you can used this!! it works!!
N95 PDA 1x18 pin
1,2 ---- Ground to pin 7 and 8 of RJ45
7 ------ TX to Pin 3 of RJ45
9 ------ RX to Pin 2 of RJ45
Reading phone info:
COM1 [Serial0] selected
19200
Initializing[6226:8A02]...
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: E553_Z14ARTVB.01.1_26S01
Version: M500Z_05C_HW
detecting structure #2...
done
imei: 35705045455674
warning: wrong packet cs
208 of 209 items cleared
1 items remains
Finished, time used: 33 sec
Remove/Install battery now !
Reading Detailed Info:
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: read/check detailed information
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [enhanced] (or higher) generation
identification data damaged
identification detection finished
device-id: 3A6F078A
protocol ver: 04
ver. sw1: E553_Z14ARTVB_E553_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E553_Z14ARTVB.01.1
ffs offset/size: 00800000/001FF000
warning: invalid identification, ask/rpl calculation reqired
error: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.3A6F078A._E553 _Z14ARTVB_E553_GPRS_MT6226_S01.01_1.BIN_89CFB3B8_. rpl
warning: unknown identification structure: E553_Z14ARTVB_E553_GPRS_MT6226_S01.01_1.BIN_89CFB3 B8
error: ASK file can't be created, user action required:
1. download latest software from support area and try again !
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read detailed information, ask/rpl" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
detection phase #3...
done
detecting structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
eeprom element #1 detected ok
detecting languages...
language parameters detected
detected languages: Ru En Th Vn Ar
Finished, time used: 113 sec
Formatting:
IMEI Rebuilding:
Action: imei
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: M500Z_05C_HW
Software version: E553_Z14ARTVB.01.1_2
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
new imei: 351758000655694
imei verified Ok
Finished, time used: 13 sec
Power off phone now !
Regards...
Rhonn
