Old 05-29-2009, 10:59   #1 (permalink)
Member: 582624
Thanks Meter: 4
ZTC N95 fullflash need
Please upload fullflash for ZTC N95. Dead after format! Used fullflash from Infinity support-screen didn't show! Thanks.
Old 05-29-2009, 12:03   #2 (permalink)
malpinssa's Avatar
Member: 476420
Sonork: 100.1605239
Thanks Meter: 164
i dont tank is dead after format it.bro you can try with full batrier .i hope it will be ok
Old 05-29-2009, 12:55   #3 (permalink)
Member: 582624
Thanks Meter: 4
Tried with fully charged battery, the same problem! I can hear the sound of switching on phone, but no screen!
Old 05-29-2009, 20:52   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
post first formating log.
you can find it in operatio.log file, chinese miracle directory
Old 05-31-2009, 10:46   #5 (permalink)
Member: 582624
Thanks Meter: 4
==== log: [28.05.2009 22:26:20] ====
COM8 [VCP0] selected
module v2.73
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:B1E4:6A85
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.A8A7C180.[E553_XZY1PA_E553_GPRS_MT6226_S01.01_1.BIN_558D361A].rpl
identification#1 detection finished
device-id: A8A7C180
identification#1 protocol ver: 04
ver. sw 1: E553_XZY1PA_E553_GPRS_MT6226_S01.01_1.BIN
ver. sw 2: E553_XZY1PA.01.1, E5C972AA
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
Do you want to use standard eeprom address: 00800000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_A8A7C180_E553_XZY1PA_E553_GPRS_MT6226_S0 1.01_1.BIN_558D361A_20090528-223043.B0X.bin
Finished, time used: 247 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
==== log: [28.05.2009 22:34:50] ====
module v2.73
Action: repair security area
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
high speed boot Off
Boot Done
Initialize ...
flash: EC257E25082501:FFFFFF00000000
Initialize Done
Set baud ...
921600
Set baud Done
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detecting security area (code #2)...
security area (code #2) is absent
Write ...
Write Done
Finalization ...
Finalization Done
Finished, time used: 181 sec
==== log opened: [28.05.2009 22:42:15] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.73
S/N: 66C4:0112
Wait...
Done
==== log opened: [28.05.2009 22:42:44] ====
S/N: 66C4:0112
Wait...
Done
Action: read information
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
baud set to: 19200
error: connection failed !
operation failed !
Finished, time used: 78 sec
Power off phone now !
Loading file v.02...
ZTC-N95_LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_ 48_12_16m_En_Ru_Fr_Th_Vn_Ar.B0M.htm loaded
identification#1 protocol ver: 05
ver. sw 1: LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 2.BIN
ver. sw 2: MAUI.06A.W06.48.12, 2EAF2D75
Loaded file w/protection: security area (code #1)
==== log: [28.05.2009 22:45:51] ====
module v2.73
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
eeprom backup enabled, it may takes several minutes !
Boot ...
error: can't detect device
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 15 sec
==== log: [28.05.2009 22:46:31] ====
module v2.73
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
Boot Fail
==== log opened: [28.05.2009 22:48:12] ====
S/N: 66C4:0112
Wait...
Done
==== log: [28.05.2009 22:48:34] ====
module v2.73
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
high speed boot Off
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
What to do:
.damaged firmware
.damaged hardware
standard eeprom/ffs offset assigned: 00E00000
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20090528-225111.B0E.bin
Write ...
.damaged firmware
.damaged hardware
security area (code #1) calculation...
done
Write Fail
Finished, time used: 152 sec
==== log: [28.05.2009 22:51:36] ====
module v2.73
advanced flash detection disabled
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
high speed boot Off
Boot Done
Initialize ...
flash: Samsung D 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
What to do:
2. set "Advanced chip detection method" box CHECKED !
.damaged firmware
.damaged hardware
ffs chip: 00
reading: eeprom...
file saved: C:\Documents and Settings\Javid\Рабочий стол\eeprom_20090528-225510.B0E.bin
Write ...
.damaged firmware
.damaged hardware
done
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 579 sec
==== log: [28.05.2009 23:01:47] ====
module v2.73
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
high speed boot Off
Boot Done
Initialize ...
flash: EC257E25082501:2BEA0000000000
Initialize Done
Set baud ...
921600
Set baud Done
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.A8A7C180.[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 2.BIN_8AD250D1].rpl
device-id: A8A7C180
ffs offset/size: 00E00000/00200000
Write ...
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_A8A7C180_LEDA26_06A_PCB01_GPRS_MT6226_S0 1.MAUI_06A_W06_48_12.BIN_8AD250D1_20090528-230415.B0X.bin
Finished, time used: 145 sec
eeprom_20090528-225510.B0E.bin loaded
==== log: [28.05.2009 23:09:44] ====
module v2.73
skip: Firmware
skip: Customization
skip: Eeprom/ffs
error: no data to write !
==== log: [28.05.2009 23:10:00] ====
module v2.73
skip: Firmware
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
high speed boot Off
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
device-id: A8A7C180
standard eeprom/ffs offset detected: 00E00000
ffs chip: 00
reading: eeprom[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 2.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 2.BIN]_20090528-231306.B0E.bin
Write ...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_A8A7C180_LEDA26_06A_PCB01_GPRS_MT6226_S0 1.MAUI_06A_W06_48_12.BIN_8AD250D1_20090528-231321.B0X.bin
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_A8A7C180_LEDA26_06A_PCB01_GPRS_MT6226_S0 1.MAUI_06A_W06_48_12.BIN_8AD250D1_20090528-231353.B0X.bin
Finished, time used: 231 sec
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [28.05.2009 23:14:22] ====
module v2.73
Action: reset settings
19200 autodetect
CPU: MT6226
high speed boot Off
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.06A.W06.48.12
Version: HEXING26_06A_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 150
warning: wrong packet cs
items cleared: 150 of 150
building list...
done
items remains: 0
Finished, time used: 55 sec
Action: imei
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: HEXING26_06A_HW
Software version: MAUI.06A.W06.48.12"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei: 350448011234561
verification Ok
Finished, time used: 36 sec
Old 06-01-2009, 00:41   #6 (permalink)
Member: 148515
hello!
flashfiles/ChineseMiracle/_MT6226/E553_XZY1PA_E553_GPRS_MT6226_S01.01_1__Nokia-N95_16m_En_Cn.B0M.bin
Old 06-01-2009, 14:23   #7 (permalink)
Member: 582624
Thanks Meter: 4
Great work. Thanks. Worked! Flashed, then repaired security area!
ztc-n95 meeza_84 Infinity-Box 1 08-24-2009 08:52
N95 8gb Rm-164 fullflash needed abdoune Infinity-Box 10 05-30-2009 16:00
ZTC D260 FullFlash JayDi Infinity-Box 1 10-22-2008 15:46
ztc n95 dead raffazila Various 0 02-11-2008 13:46
6210 4.08 ppmR, fullflash needed.. anyone? trafix Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-16-2001 20:57
Page generated in 0.28465 seconds with 9 queries
