10-04-2010, 11:41 | #1 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | ZTE S315 Read / Unlock Problems I need unlock this phone model but I get this problems, herewith logs: COM9 [VCP0] selected module v1.78 Device: ZTE-S315 Checking data, wait... Action: read ffs/eeprom Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... error: can't run preloader: 01 Release Power button now Boot Failed Finished, time used: 7 sec Remove/Install battery now ! And I get different information about pinout from ur side, see : configuration: pinout 404 Cable name: ZTE-S315 ------------- 1 2 3 4 5 \6 7 8 9 10 / 1: Gnd 9: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3) 10: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2) but I tried not works pinout, pinfinder ver 1.20 found it pinout as follows: software version: 1.20 cable type: 2x5 (L10C) platform: CPU independent (autodetect) algorithm searching adapter at COM9... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. detecting pins... detected baudrate: 115200 result: Rx:4 Tx:5 time required: 82 sec Please info.... how to solve this problems. Thks & Regards, |
The Following User Says Thank You to abellcell For This Useful Post: |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
