10-05-2007, 20:42 | #1 (permalink) |
Freak Poster Join Date: Mar 2005
Member: 129719 Status: Offline Thanks Meter: 5 | 6131 powers off in process |
10-05-2007, 20:51 | #2 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Ukraine
Member: 289200 Status: Offline Thanks Meter: 219 | Quote:
check tp. maybe it's bad. I unlock many times 6131 and all ok. And I enter code manually. | |
10-05-2007, 20:53 | #3 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | I had the same problem with one, Check the version in phone, make correct testpoint, use dku2 modified cable.. Post back...... |
10-05-2007, 21:10 | #4 (permalink) |
Member: 129719 Status: Offline Thanks Meter: 5 | yes phone works good without test point. it will not power on if connected to box so i power on before. i dont have dku2 cable only regular data cable but gives the same power off problem without easy uid. tnx |
10-08-2007, 02:45 | #7 (permalink) |
Member: 129719 Status: Offline Thanks Meter: 5 | I fix the shut down problem by connecting phone first. then powering on uid box. However in using easyuid, when the unlock code is introduced (by easyuid), then the process stops there. I donīt see phone unlocked. What can this problem be? |
10-08-2007, 14:42 | #8 (permalink) | |
Try to enter code manually. | |
whats happen whit bug power off in asic2 imei change??? | marioarq | Universalbox | 0 | 08-11-2007 21:53 |
6131 power off in GALLERY=>THEMES | idhamitov | Nokia Base Band 5 ( BB-5 ) | 1 | 01-06-2007 21:01 |
6600 power off in few sec | kiran | WD2 & APE (Symbian Phones) | 5 | 11-04-2006 00:35 |
power off in messaging | travolta | Siemens Hardware Repair Area | 2 | 04-13-2005 07:04 |
Help!!! Sl45i Power Off in the time of charging! | TNT | x1x to x45/x50 | 1 | 09-22-2002 19:01 |
