Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UID - Box
Old 04-21-2008, 12:07   #1 (permalink)
Crumarix1's Avatar
Member: 84300
Thanks Meter: 74
#pw+..# result: 0c PROBLEM
well,2 days I try to unlock 6300,and finaly I did .
server is working,but after send unlock code i rcw error above,and it stuck abou test 04,03...
What I doing wrong ?
I use usb cable - OK !
Use power souply 9v for UID - OK !
For phone conection,i maded usb cable,like in manual description,phone is conected and well recognized,and in test mode also..- OK !
Readed 308 field OK !
Phone conected OK !
Test point soldered, GREAN and YELOW ( in my case BLUE )...OK !
BUT IT CAN'T UNLOCK PHONE UNTIL U CONECT BLACK GROUND WIRE FROM UID BOX,always stuck in after inputcode part.
after conecting ground,phone was unlocked in 1 try !
Old 04-25-2008, 13:01   #2 (permalink)
Speed_Demon's Avatar
Member: 249757
Sonork: 100.1601084
Thanks Meter: 117
use search function...............................been posted before......
Old 04-29-2008, 08:31   #3 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
Phone conected OK !
Thats nice u unlocked the phone ....
so u mean to say that ... there was a GND problem???????
Old 04-30-2008, 21:07   #4 (permalink)
Crumarix1's Avatar
Member: 84300
Thanks Meter: 74
Yes ! Actualy, I was broken my brain at half to imagine all conection of wires from box,and in combination with usb cable,and,in first variant I solved,that if I use prepared usb cable,with conection for batt conector,I need only conect green and yelow wire from box.And,prog was worked and readed codes but unlock was not maded until I not conected black ( ground) wire from box to metal chasis on phone.
must say,explanation of conection in manual is not so bright.Still dont know where I need to conect red,black and brown wire from box,in case i not using prepared usb cable,coz when i mesure voltage on that wires,it'i no volts al all.
Page generated in 0.14436 seconds with 10 queries
