10-28-2008, 23:26 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Glasgow
Member: 41440 Status: Offline Thanks Meter: 0 | W380i unlock problem |
10-29-2008, 07:22 | #2 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 724413 Status: Offline Thanks Meter: 205 | w380 signed driver download from here:http://www.shenliang.net |
10-29-2008, 14:35 | #3 (permalink) |
Member: 41440 Status: Offline Thanks Meter: 0 | hi i tried those drivers and its still the same when i plug the phone in im prompted to install the drivers but for each one it says not installed as it could not find the drivers, i deleted them in device manager reinstalled but its till the same i need help to do the unlock2 as at the moment the phone will not take any simcard many thanks |
10-29-2008, 17:50 | #5 (permalink) |
Member: 41440 Status: Offline Thanks Meter: 0 | thats it the connector part has problem!!! i dont think so or i would not have been able to do the remove lock1 would i there is no problem with the phone or cable i just cant install the drivers some support please |
11-01-2008, 07:37 | #6 (permalink) |
Freak Poster Join Date: Oct 2005 Location: perth aust.
Member: 188959 Status: Offline Thanks Meter: 7 | Not sure if this will help WR , but connect the phone to your system, without SEKing turned on . Let the computer find the phone. When it does , let it load the drivers autoimatically [have you downloaded the usb drivers?]. Sometimes it takes a while , and needs to be done in 2 sections.If it can't find the drivers , rip 'em off EMMA, and you should be ok. At times you get the instal wizard , sometimes not. I am computer Dill , so it took a while to figure it out , but it works for most phones I unlock, I put on system first... Hope it helped you!! |
w380i unlock | good-boy | Sony Ericsson | 10 | 07-11-2013 20:44 |
w380i unlock prob | EJAZGUL | Sony Ericsson | 8 | 05-31-2013 03:06 |
W380i unlock problem | lucky_gsm | SETool2 | 5 | 11-25-2009 12:05 |
W380i Cid53 problem after flash ??? | ghost9800 | Sony Ericsson | 5 | 05-04-2009 18:20 |
>>> SE W380i Unlocked Ok <<< | zeel_zeel | SETool2 | 0 | 01-16-2009 15:04 |
