04-17-2008, 11:26 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: bangladesh
Member: 545768 Status: Offline Thanks Meter: 19 | SEKING SERVER Z310 Unlock Solution ??????? Help Me [ --- EraseLock --- ] Power off phone with battery,Press C key & plug DCU-60 in ... Model wrong! Time: 00min 07sec [ --- EraseLock --- ] Power off phone with battery,Press C key & plug DCU-60 in ... Connect to phone success! Baseband ID000 Protocol version:0301 Color: Red EROM CID:52 OTP CID:51 OTP LOCK:1 IMEI:35756001625791 Connecting server... Connect to server success! User authen success! Erasing Lock Request Sent! Credit need:4, credit left:20 Important notice:your requested data has been sent to server for calculation,erasing lock is not done currently,you should re-erase lock later until appearing erase lock success in message box.to do step 2 unlock will waste your credit if you don't get the message erasing lock success.erase lock only deducts credits at 1st time for the same phone. Time: 00min 08sec help me please, now what i do?????????? Last edited by adil_aimtel; 04-17-2008 at 11:36. Reason: WRITE RONG |
04-17-2008, 12:01 | #3 (permalink) |
Member: 545768 Status: Offline Thanks Meter: 19 | Important notice:your requested data has been sent to server for calculation,erasing lock is not done currently,you should re-erase lock later until appearing erase lock success in message box.to do step 2 unlock will waste your credit if you don't get the message erasing lock success.erase lock only deducts credits at 1st time for the same phone. Time: 00min 08sec Brother 3 no step ,what i am do, |
04-17-2008, 14:31 | #4 (permalink) |
Freak Poster Join Date: Sep 2006 Age: 44
Member: 344661 Status: Offline Thanks Meter: 3 | In the second step you sent the request to server, you must wait a time (ten min, one hour, two hour) and again click on EraseLock, if your request is ready the client show you "Erase sucess" (don't worry this time not will deducts your credits)... Finaly, power on the phone, install the drivers and click on Unlock, wait and your phone is FULL UNLOCK... |
04-17-2008, 14:34 | #5 (permalink) |
Junior Member Join Date: Apr 2008
Member: 747612 Status: Offline Thanks Meter: 0 | to adil_aimtel: 1.that means you should wait a moment (for example 1 hour or more than), you try to press (1)erase lock button again. 2.you have to repeat above procedure if you can't get erasing lock success message. 3.you can press (2)unlock button after you get erasing lock success message. |
6210n unlock please help me please | AVCITHETCNC | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-29-2010 18:21 |
samsung E315 fast discharging any solution help me plz | shani72 | Samsung Hardware Repair | 0 | 06-12-2009 05:13 |
where can i find z310 test point? help me pls! | kiper2009 | SETool2 | 0 | 08-10-2008 03:30 |
Need Z310 Unlocking solution!!!!!! | Z-RocK | Cruiser Suite | 3 | 09-05-2007 02:57 |
