02-27-2008, 11:17 | #1 (permalink) |
Registered User Join Date: May 2007 Location: india
Member: 511520 Status: Offline Sonork: 100.1573642 Thanks Meter: 127 | 5200 Unlock Failed Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.92_13-10-06_RM-174_(c)_Nokia. IMEI: 354565013396449 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-174_354565013396449_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia.__27_02_2008__13_30_55.bin Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.92_13-10-06_RM-174_(c)_Nokia. IMEI: 354565013396449 SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_354565013396449_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Unlock fail. Please try again. WHAT I DO SIR NOW ANYBODY HELP ME ARGENT B.R. |
5200 Unlock Fail... | LoveLess | Universalbox | 22 | 09-05-2008 18:56 |
other more 5200 unlock fail TELCEL | cordd | J.A.F. Plus | 0 | 05-27-2008 00:51 |
Nokia 5200 Unlock Fail.. | Red-1Lotfi | BB5BOX | 4 | 11-17-2007 13:29 |
5200 uNLOCKING fAIL | Hazard | BB5BOX | 2 | 11-06-2007 18:51 |
5200 unlock fail | Bakl | BB5BOX | 5 | 10-09-2007 10:16 |
