Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2005 Age: 38
Member: 159411 Status: Offline Thanks: 6
| 6131 unlock fail with bb5 box 6131 cant unlock with bb5box Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 354566018896953 SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-115_354566018896953_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-115_354566018896953_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2006 Location: ROMANIA/Alexandria Age: 33
Member: 230301 Status: Offline Sonork: 100.106864 Thanks: 211
| write backup file: RM-115_354566018896953_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin and see to put corect tp becose you make rong tp (see if is make good contact ) or flash whit another version that is the problem. |
| | #4 (permalink) | |
| Quote:
Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 354566018896953 SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-115_354566018896953_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-115_354566018896953_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2620100000000000 Block 1: OPEN Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| problem unlock 3250 with BB5-BOX | iran-mobile-team | BB5BOX | 3 | 04-08-2008 11:51 |
| 2670 4.22 unlock failed with mt-box | SALNAI | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 04-01-2008 10:26 |
| 6086 unlock fail with bb5 box | Bao Tran | BB5BOX | 22 | 12-25-2007 00:06 |
| 5300b ver 4.51 unlocked susecfull with BB5 Box.....100000% | Bao Tran | BB5BOX | 0 | 10-15-2007 08:10 |
| 2610 unlock failed with ub box | melsoft | Universalbox | 7 | 12-07-2006 12:30 |
