02-23-2008, 20:55 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: I'm back to business
Member: 184793 Status: Offline Sonork: 100.1574609 Thanks Meter: 45 | i had 290 pcs to unlock with suppoted version 4.10 +3.91 ,but 13 pcs didn't want to be unlock ;so i make upgrade to 4.10 for fones with 3.91 that all good luck Br LordMen007 |
02-24-2008, 15:17 | #6 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Romania
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | look here log Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-200 Version: V_04.10_21-12-06_RM-200_(c)_Nokia IMEI: 356297018145864 SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-200_356297018145864_Locked_Keycnt_0_Fbuscnt_0__V_0 4.10_21-12-06_RM-200_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. |
02-24-2008, 15:19 | #7 (permalink) |
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | another log another version if need post allll ~20 log Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-200 Version: V_03.91_25-09-06_RM-200_(c)_Nokia IMEI: 356297018145864 SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-200 Version: V_03.91_25-09-06_RM-200_(c)_Nokia IMEI: 356297018145864 SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-200_356297018145864_Locked_Keycnt_0_Fbuscnt_0__V_0 3.91_25-09-06_RM-200_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. |
02-24-2008, 18:18 | #10 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Slovakia VT
Member: 59529 Status: Offline Thanks Meter: 115 | unlock 6151 for me work fine Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-200 Version: V_04.10_21-12-06_RM-200_(c)_Nokia IMEI: 356297015****** SP LOCK status: Config Key: 2720500015194980 Block 1: CLOSED Type 5 Data: 27205F Block 2: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-200_3562970******x_Locked_Keycnt_0_Fbuscnt_0__V_04 .10_21-12-06_RM-200_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2720500015194980 Block 1: OPEN Type 5 Data: 27205F Block 2: OPEN Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
6151 Unlocking Problem...........[Solved] | Indus | JAF No Tp Unlocker by Cinek | 3 | 04-08-2009 06:39 |
6151 unlock problem | ABI-GSM | BB5KING | 2 | 11-11-2008 15:21 |
6151 unlock problem | sonitex | BB5BOX | 3 | 02-11-2008 10:42 |
unlock problem 6151 | jacekchec | MT-BOX | 9 | 09-03-2007 09:47 |
6151 SIM problem | backbiter17 | Nokia Hardware & Hardware Repair | 0 | 03-08-2007 20:13 |
