Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: Egypt Age: 24
Member: 629039 Status: Offline Sonork: 100.112945 Thanks: 347
| 6280 spansoin need help with version 041 i need to know when i chouse my pnoes as ad0 *** spansion and when as ad1***xx spansion and how to downgrad my box again to version 037 plz help |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Turkiye :GsmdunyasıTeamŽ Age: 42
Member: 115596 Status: Online Thanks: 381
| 6280 spansoin version 041 ok Good microscope and tp well ------ Operation: UNLOCK V1 Date: 07-04-2008 Time: 18:46:34 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 35455801079****** SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_3545580107***XX_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-78_354558010***XX_Locked_Keycnt_0_Fbuscnt_0__V_06. 10_21-12-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2620100000000000 Block 1: OPEN Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Ireland / Belarus
Member: 234917 Status: Offline Thanks: 161
| ad1 is the original data tp. ad0 is the new "easier" data tp. the choice is yours to decide which tp to use. see the tp picture on www.bb5box.org To downgrade your box use the box updater found at http://66.199.236.202/BB5_Updater.zip to change the firmware. If you use 0.37 then you don't have the choice of tp - just the more difficult ad1. |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Rawalpindi Pakistan Age: 8
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks: 283
| you can find the software on the support site here is the direct link http://66.199.236.202/BB5_Updater.zip for downgrade and upgreade for the versions |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| i need help with 6280 after downgrade dead !!! | lukasss | Nokia Base Band 5 ( BB-5 ) | 9 | 04-11-2008 17:49 |
| Need help with the New version of KKclient v1.47 | xiuxiu19 | KULANKENDI Server | 0 | 03-20-2007 01:46 |
| 6280 need help with phoenix..flash files! | kippe | Nokia Base Band 5 ( BB-5 ) | 0 | 08-05-2006 20:13 |
| Need help with unlock k700i and t610 new version with total multiserver! | mobile_2003 | TOTAL MultiServer | 4 | 10-21-2004 13:57 |
| need help with 525 version 106kr126 | Newsted | BF, BG, TH, BHx Series | 4 | 12-27-2003 17:13 |
