10-06-2007, 04:38 | #5 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 473830 Status: Offline Thanks Meter: 2 | to dau I up phone ver 5.0 not unclock wait !!!!helps me ple !!! Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 356261016071704 SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_35626101xxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_35626101xxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 |
10-06-2007, 05:36 | #7 (permalink) | |
Product Supporter Join Date: Oct 2002 Location: Philippines/Shenzhen, China Age: 58
Member: 16816 Status: Offline Sonork: 100.42691 Thanks Meter: 105 | Quote:
br nlogomaster www.gsm-traders.com | |
6280 keypad 123 and 6300 all keypad not working | destinyhammed | Nokia Hardware & Hardware Repair | 5 | 10-19-2009 15:23 |
N77 not unclock???????????????? | raie | Universalbox | 3 | 04-23-2008 11:25 |
6300 chip ATD not unclock it??? | thanhhai0481 | BB5BOX | 2 | 12-13-2007 14:47 |
5300b T-mobile Flash all ver not unclock???? | thanhhai0481 | BB5BOX | 4 | 12-08-2007 16:22 |
what wrong with my china phone 6300?? All Succes Can Not Powered...!! | bestncheap | Infinity-Box | 9 | 09-13-2007 04:25 |
