11-19-2007, 11:16 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 621628 Status: Offline Thanks Meter: 0 | 6300 Atb Problem but anotehr one making problem Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_356401019247113_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_356401019247113_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 500 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. What is Problem |
6300 charging problem. | maheshsaiganesh | Nokia Hardware & Hardware Repair | 6 | 10-18-2010 01:13 |
6300 ATB unlocked succesfull | hassan1975 | BB5BOX | 1 | 10-01-2007 14:37 |
6300 Atb Chip | phoneworldleice | BB5BOX | 10 | 10-01-2007 10:41 |
6300 unlock problem | ALVYDAS007 | Nokia Base Band 5 ( BB-5 ) | 1 | 07-05-2007 09:33 |
6300 video problem and request | lotusbrs_trl | Nokia Multimedia | 0 | 05-20-2007 10:41 |
