Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 04-25-2008, 18:44   #1 (permalink)
Member: 739774
Thanks Meter: 89
6300 can not unlock, downgraded, full flashed, not helped! It's Lock!!
Hello guys,
I have a problem with unlocking 6300 with BB5 Box, 6300 chip numr: (spansion )72NS256
i writed also PM 308 backup! not helped!
Phone was Version 5.52, i flashed to 6.01!
Here is the log:
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-217
Version: V_06.01_16-01-08_RM-217_(c)_Nokia.
IMEI: 352042029971948
SP LOCK status:
Config Key: 2041600000000000
Block 1: CLOSED Type 5 Data: 20416F
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-217_352042029971948_Locked_Keycnt_3_Fbuscnt_10__V_ 06.01_16-01-08_RM-217_(c)_Nokia..bin
already exist
Counter limit reached. Please write PM 308 backup.
Type: RM-217
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
But it say again!
is here any solution??
Thanx
Old 04-25-2008, 18:47   #2 (permalink)
Member: 739774
Thanks Meter: 89
what means that? 3 times is max trying?? after 3 times phone can not be unlock??
Plz answer my question
Thanx to every body
Old 04-25-2008, 19:25   #3 (permalink)
Member: 588059
Thanks Meter: 47
Thanx to every body
Seems you received this phone with all counters at max. values. To unlock you have to reset counters. Use SEARCH and read this forum for more informations, even what you posted here could be solved if YOU READ some old posts!!!
Old 04-25-2008, 21:15   #4 (permalink)
Member: 739774
Thanks Meter: 89
Ok, thank u very much
<<< K770i Phone Lock - can i remove without full flashing? >>> khadim100 SETool2 5 01-05-2010 06:50
U970 can,t unlock after full flash misal Easy-Unlocker 4 12-08-2008 10:13
Gobi help please - u8180 can not unlock after write flash emilkawa VygisToolbox 1 07-10-2008 16:29
N95 sw 12.0.013 can not unlock/downgrade foony MT-BOX 1 07-23-2007 22:30
need full flash for t65 it's really chip_2000 Sony Ericsson 0 11-27-2003 12:21
Page generated in 0.16386 seconds with 9 queries
