10-30-2008, 14:55 | #4 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | @mc_denz Forgive .... check that this well-connected power hooks and turn it .... If you want, just to prove, put it on display for you to see if they test mode |
10-30-2008, 15:11 | #5 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 210518 Status: Offline Thanks Meter: 1 | tried power up blue light flash but nothing on screen i read all about user code but there is no user code when i boot normsll it ask me start up without sim? cable is brand new used twice been working fine |
11-12-2008, 20:52 | #6 (permalink) |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 14047 Status: Offline Thanks Meter: 166 | make shore red vcc is right and bsi yellow is right also to try to read without vcc and bsi put battery in fone and just use cable to botton i mean test point cable and press info see if the fone reads if the fone reads cheack vcc and bsi clips on cable to make shore its still connected ok |
11-13-2008, 04:04 | #7 (permalink) |
Major Poster Join Date: Jan 2008
Member: 673993 Status: Offline Thanks Meter: 3 | Also, Make sure USB cable is shorter than 1~meter. Make sure there is no Grit on System connector and Red is to + and Yellow is to Data terminal NOT negative. I find using an elastic band to hold the RJ45 connector to the box helps, cause it does slide around a bit. |
LG KF900 can't connect with the box | sunshinelin | VygisToolbox | 0 | 07-05-2009 21:52 |
6300 can't unlock with BB5 Box | namchito | BB5 Box by D.K. | 2 | 07-26-2008 07:54 |
6300 can't unlock with BB5 Box | namchito | BB5 Box by D.K. | 3 | 07-25-2008 12:15 |
Trouble Unlocking 6300 With BB5 Box - Nokia 6300 Using Test Point Jig- Please Help :) | dave.cullen | BB5BOX | 7 | 02-04-2008 09:23 |
nokia 6300 Connecting to BB5 Box | simlock | BB5BOX | 8 | 01-15-2008 21:26 |
