02-12-2008, 05:20 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 665219 Status: Offline Thanks Meter: 0 | 6300 probleme beblocage Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.70_24-01-07_RM-217_(c)_Nokia. IMEI: 358648015309747 SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_358648015309747_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 500 miliseconds Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries |
02-12-2008, 08:36 | #3 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: algeria Age: 53
Member: 189532 Status: Offline Thanks Meter: 28 | hi mate Quote:
surely u r not making good test point ......... now u have to rewrite bkp readen already by box to reset counter then try with good test point ....... u can also upgrade phone version then try again br | |
nockia 6300 problem | sal_pak | Nokia Hardware & Hardware Repair | 1 | 05-29-2008 22:28 |
6300 as like org.6300 problem | khokonhajigonj | Chinese Models & Cloned Phones | 0 | 05-28-2008 20:31 |
6300 problem, please help. | EFOKORKU | MT-BOX | 9 | 08-10-2007 12:14 |
6300 problems | Vinod Rana | MT-BOX | 2 | 06-30-2007 11:42 |
