02-21-2008, 10:15 | #1 (permalink) |
Junior Member Join Date: Nov 2007 Location: Galati, Romania Age: 53
Member: 638539 Status: Offline Thanks Meter: 2 | 6300 unlock fail with spansion flash chip Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 359812018227913 SP LOCK status: Config Key: 2261000000000000 Block 1: CLOSED Type 5 Data: 22610F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_359812018227913_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 Trayed many time with gnd near the flash ic, with gnd and without gnd, etc. etc.......again and again (~30 times) same error. Please, need an advice.............. good advice...... Thx in advance! |
02-25-2008, 23:00 | #8 (permalink) |
Crazy Poster Join Date: Oct 2005
Member: 194676 Status: Offline Thanks Meter: 2 | unlock faill Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.20_05-12-06_RM-217_(c)_Nokia. IMEI: 354827011559448 SP LOCK status: Config Key: 7223400000000000 Block 1: CLOSED Type 5 Data: 72234F Block 2: CLOSED Type 5 Data: 72234F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.20_05-12-06_RM-217_(c)_Nokia. IMEI: 354827011559448 SP LOCK status: Config Key: 7223400000000000 Block 1: CLOSED Type 5 Data: 72234F Block 2: CLOSED Type 5 Data: 72234F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_354827011559448_Locked_Keycnt_0_Fbuscnt_0__V_0 4.20_05-12-06_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 7223400000000000 Block 1: CLOSED Type 5 Data: 72234F Block 2: CLOSED Type 5 Data: 72234F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. and again .... Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.20_05-12-06_RM-217_(c)_Nokia. IMEI: 354827011559448 SP LOCK status: Config Key: 7223400000000000 Block 1: CLOSED Type 5 Data: 72234F Block 2: CLOSED Type 5 Data: 72234F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.20_05-12-06_RM-217_(c)_Nokia. IMEI: 354827011559448 SP LOCK status: Config Key: 7223400000000000 Block 1: CLOSED Type 5 Data: 72234F Block 2: CLOSED Type 5 Data: 72234F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_354827011559448_Locked_Keycnt_0_Fbuscnt_0__V_0 4.20_05-12-06_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 7223400000000000 Block 1: CLOSED Type 5 Data: 72234F Block 2: CLOSED Type 5 Data: 72234F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. any idea?? Best Regards. |
02-26-2008, 22:31 | #11 (permalink) |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | all supported from today, have a look at this post plz http://67.15.194.130/vbb/showpost.ph...07&postcount=3 B.R., Raskal |
02-27-2008, 15:10 | #12 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 42
Member: 136598 Status: Offline Thanks Meter: 3 | when touching testpoints on 6300 dont touch directly on top of the solder balls, this is not a good connection and i have had many problems by doing it like that. Touch it on the side of the solder ball were you can see the brown circuit board this gives a better connection and unlocks without error. good luck |
02-27-2008, 16:30 | #13 (permalink) | |
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
time to close this topic. B.R., Raskal | |
PLs share which box is best for unlocking 6234 with spansion chips! plss comment!!! | ReyTech | Nokia Base Band 5 ( BB-5 ) | 7 | 04-12-2008 19:24 |
still --> 6300 unlock fail with spansion flash chip | nikkomusa | BB5BOX | 2 | 02-27-2008 22:42 |
6300 Spansion flash chip...unable to unlock :( | XtremeGG | MT-BOX | 16 | 12-24-2007 04:11 |
Problem unlock A31 with ST flash chip | goro_bg | DreamBox | 10 | 09-25-2006 08:41 |
I have some idea how to unlock Siemens with new flash chip ! | mr_x4you | x1x to x45/x50 | 3 | 08-14-2002 14:39 |
