04-16-2008, 12:36 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 51
Member: 170494 Status: Offline Thanks Meter: 9 | 6300 unlock problem i have a 6300 to unlock but i get error. dont tell me plz serch the form. becouse i did it and about 3 days i see this forum. i tried ewry methode and only 2 time i could unlock this phone but i get contact service after and then i have to rewright PM and then i get buck a locked phone. can some1 give an advice exapt serch the forum. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 352042020691313 SP LOCK status: Config Key: 2041600000000000 Block 1: CLOSED Type 5 Data: 20416F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_352042020691313_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2041600000000000 Block 1: OPEN Type 5 Data: 20416F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull regards |
04-16-2008, 14:44 | #4 (permalink) |
Member: 170494 Status: Offline Thanks Meter: 9 | hi hi i tried few time few methode (downgrade, upgrade, pm repair ...) but no succes. thanks\ Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 352042020691313 SP LOCK status: Config Key: 2041600000000000 Block 1: CLOSED Type 5 Data: 20416F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 3 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_352042020691313_Locked_Keycnt_1_Fbuscnt_3__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 14 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020111 |
04-17-2008, 23:42 | #6 (permalink) | |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Quote:
55 - communication error (usualy when connect TP in wrong location | |
04-18-2008, 10:25 | #7 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 53
Member: 4611 Status: Offline Thanks Meter: 68 | Just unlocked 2 Spansion based 6300 with the same problems, and the same log. I flashed to 6.01 and they both unlocked 1st time. Iknow you have said that you have up / downgraded, but it worked for me. |
6300 unlock problem | Mr Twitch | MT-BOX | 5 | 10-01-2007 09:42 |
6300 unlocking problem. | mobile_2003 | MT-BOX | 2 | 09-22-2007 11:42 |
6300 unlock problem REVISIOn=D | ozeracar | MT-BOX | 27 | 09-03-2007 12:22 |
6300 unlock problem???? | anowar_47 | MT-BOX | 7 | 08-04-2007 20:39 |
6300 unlock problem | ALVYDAS007 | Nokia Base Band 5 ( BB-5 ) | 1 | 07-05-2007 09:33 |
