09-29-2007, 06:15 | #1 (permalink) |
Insane Poster Join Date: Sep 2005 Location: London, UK Age: 47
Member: 176370 Status: Offline Thanks Meter: 1 | 6300 version 5.00 not being done!! need help here Im not sure if its me or what it is but i cant manage to unlock a simple 6300 version 5.00 with the bb5box. I do everything fine, connect tps and the sw detects that, but then gives me codes like *#1234567890+1# etc etc (loads of them) then says all tries are used. So i have to write 308 back into phone. then i tried downgrading it to version4.70 it then it unlocked without any problems at all. So the question was that why does the software give those wrong codes when that version is supposed to be supported?? |
09-29-2007, 08:35 | #3 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | am meeting the same exact problem on a 5300 with ATB flash. from 3.92 upgraded to 5.00 and it would not unlock as it can be seen in this log. Am using firmware 5 with v0.0.2.1. Tried about 5 times and always the same problem. This is its log. Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 352734017846039 SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-146_352734017846039_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-146_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock fail. Please try again. |
09-29-2007, 10:35 | #4 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | SP area corupted. If it worked before upgrade, put back 3.92, write backup (if you have one from flasher software). Read info with flasher software, you will see if phone was corupted when you received or not. And unlock again (on 3.92 version, it working unlock well), if with 3.92 Sp area not corrupted. If on 3.92 same info with SP area corupted, then you need RPL, because this phone was damaged when you received. Quote:
6300 version 5.00 Unlocked by Thomas Pkey FREEEEE | boy_muslim | BB5 No TP By Jafsupport | 10 | 09-25-2009 02:31 |
Problem unlocking 6300 version 5.00...also 5.52 | Unlocker AL | J.A.F. V-SPEC | 20 | 06-25-2008 19:23 |
needed file nokia 6300 version 6,00 plz | m_arifamiry | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-16-2008 16:51 |
Nokia 7110 v 5.00 Desperado style i need help | jj008 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-09-2001 17:19 |
