03-08-2008, 09:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Dubai
Member: 45561 Status: Offline Thanks Meter: 59 | After Update My Box To 4.00 Now Box.... Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 353949013844494 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_353949013844494_Locked_Keycnt_3_Fbuscnt_10__V_0 6.43_30-03-07_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-78_353949013844494_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F PleaSE I NEED SOME ADVISE FROM THAT POINT |
03-08-2008, 10:07 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: INSIDE-SPT
Member: 216769 Status: Offline Sonork: 100.1576865 Thanks Meter: 225 | ------ Operation: UNLOCK V1 Date: 08-03-2008 Time: 15:09:27 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v48_26-06-07_RM-133_(c)_Nokia. IMEI: 353641016546313 SP LOCK status: Config Key: 5150200000000000 Block 1: CLOSED Type 5 Data: 51502F Block 2: CLOSED Type 5 Data: 51502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_353641016546313_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v48_26-06-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5150200000000000 Block 1: OPEN Type 5 Data: 51502F Block 2: OPEN Type 5 Data: 51502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-08-2008, 10:12 | #4 (permalink) |
Member: 216769 Status: Offline Sonork: 100.1576865 Thanks Meter: 225 | ------ Operation: READ PM 308 Date: 05-03-2008 Time: 17:51:00 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353226017856919 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 4096 bytes Saving to file: RM-78_353226017856919_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia__01_03_2008__17_51_08.bin Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353226017856919 SP LOCK status: Config Key: 5150300000000000 Block 1: CLOSED Type 5 Data: 51503F Block 2: CLOSED Type 5 Data: 51503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_353226017856919_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5150300000000000 Block 1: OPEN Type 5 Data: 51503F Block 2: OPEN Type 5 Data: 51503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-09-2008, 08:55 | #6 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi Raskal plz help me with this N73 !! I try many many times but cant unlock it ! The original phone sw version is not supported RM-132 (v4.0738.3.1.1) and downgrade at RM-132 v3.0638.0.0.1 I put the gnd in others positions but always the sw try and try and cant unlock. I use a TP as I take at the support page. I attach the TP that I use. Is not a 1st N73 that I work with bb5box but is the first one using the sw version 4.0. With the others versions worked perfect ! Also I uninstalled the NSpro drivers and I use in a laptop only with bb5box sw. This is a log: Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804011****** SP LOCK status: Config Key: 722xx00000000000 Block 1: CLOSED Type 5 Data: 74402F Block 2: CLOSED Type 5 Data: 74402F Block 3: CLOSED Type 5 Data: 722310 Block 4: CLOSED Type 5 Data: 722310 Block 5: CLOSED Type 5 Data: 74810F Block 6: CLOSED Type 5 Data: 74810F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 3 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-132_354804011******_Locked_Keycnt_0_Fbuscnt_3__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020111 I stop work in this phone because the bga balls are at the last of life !! Plz help me !! Many thanks |
03-10-2008, 12:39 | #8 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: kampala uganda Age: 41
Member: 566014 Status: Offline Thanks Meter: 5 | Thanks Quote:
instead it continue till to the last when TP is not connected as yet it is as if you have pressed the clock swich but not | |
03-10-2008, 21:10 | #9 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | it worked well for me but, today soft just close when search phone i'm working with v38 without any pb hope fix the error if is soft bug..and hope more that is not my box . |
03-11-2008, 08:55 | #10 (permalink) |
Member: 45561 Status: Offline Thanks Meter: 59 | Please this problem is very common and many box out thier are not working i thougt thAT IS ia a problem to me only but i have seen 3 boxes like mine has the same problem and the team does not answer on that is it the verion 4.00 bug or it is the box gone please team help us |
03-17-2008, 15:34 | #11 (permalink) |
Freak Poster Join Date: Mar 2004 Location: MEKNES Age: 45
Member: 58404 Status: Offline Thanks Meter: 65 | HI ALL VERSION V4.00 IS WORK Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353949013283339 SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_353949013283339_Locked_Keycnt_3_Fbuscnt_10__V_0 5.92_07-09-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-78_353949013283339_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2081000000000000 Block 1: OPEN Type 5 Data: 20810F Block 2: OPEN Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfu |
After Update my UB box to version 2.8.4.2498,can't get that version,why?? | mantok | Universalbox | 5 | 11-30-2009 12:35 |
after update my box this my problem [SOLVED] | Code:L.A 22 | Cyclonebox | 10 | 08-18-2009 11:22 |
after updating my software to ver.2.24 noox box tp pictures doesn't come out:( HELP | Unlockemall | NoooX Box | 6 | 09-22-2008 19:34 |
pls help...after transfering my credits to my furous gold box.now my sefut dont ope n | razisamb | FuriousGold | 1 | 03-08-2008 08:57 |
After Update My UB to 2.05 i Can't Unlock Any Phone WHY ? | Mierdita | Universalbox | 4 | 11-21-2006 22:22 |
