11-24-2007, 20:11 | #1 (permalink) |
Insane Poster Join Date: Jun 2006
Member: 301349 Status: Offline Thanks Meter: 1 | BB5 box fw damajed plz help it says Testpoints connected OK even with out me touching anything then it goes to fail I did try 3 diffrent cables and 2 phones and the result is the same all the time PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2340000300000000 Block 1: CLOSED Type 5 Data: 23410F Block 2: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
sola bb5 rpl repair partner plz help | abi.m | Nokia Base Band 5 ( BB-5 ) | 5 | 11-03-2009 14:10 |
How to security code unlock NOKIA DCT4 BB5 phones MANUAl codes plz Help me | shivashakthi | Nokia Hardware & Hardware Repair | 1 | 01-30-2009 16:11 |
How can I unlock e62 with bb5 box tp pic plz | MR.WNKA | Nokia Base Band 5 ( BB-5 ) | 1 | 09-07-2008 10:59 |
Any Bb5 Cant Factory Set Plz Help | mian avais | Nokia Base Band 5 ( BB-5 ) | 4 | 05-25-2008 16:24 |
