11-22-2007, 04:35 | #16 (permalink) | |
No Life Poster Join Date: Apr 2004 Age: 43
Member: 61557 Status: Offline Thanks Meter: 130 | Error No USB Microscope found! Quote:
men can you please explain it clearly...when i use the new software ver 027 it need to attach a microscope unfortunately i dont have it yet i try to cancel it and the software cannot continue and eror at the end how can we mange to continue with out a usbmicroscope? thank you very much for your time. this is the eror i encounter using the new version: ------ Operation: UNLOCK Date: 18-11-2007 Time: 03:46:27 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v31_05-06-07_RM-159_(c)_Nokia IMEI: 356962011891125 SP LOCK status: Config Key: 2041600000000000 Block 1: CLOSED Type 5 Data: 20416F Block 2: CLOSED Type 5 Data: 20416F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_356962011891125_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v31_05-06-07_RM-159_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-159_356962011891125_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v31_05-06-07_RM-159_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2041600000000000 Block 1: CLOSED Type 5 Data: 20416F Block 2: CLOSED Type 5 Data: 20416F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... No microscope found! BR, DaWizard | |
11-22-2007, 05:32 | #17 (permalink) | |
No Life Poster Join Date: Nov 2004
Member: 92326 Status: Offline Thanks Meter: 205 | Quote:
if you conect directely both in usb computer, BB5 box is not recognised but if conect microscope via HUB and the box directly to USB PC IT real WORKS ! so tell the real truth to the BB5 box users ! sm4rtboy | |
11-22-2007, 10:09 | #18 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Australia, Melbourne Age: 37
Member: 3902 Status: Offline Thanks Meter: 19 | I beg to diffier guys, some ppl (and me) are having problems with BB5 box and microscope, even on new PC's, on board USB, or external hub with power supply, still have problems. Please read on here http://forum.gsmhosting.com/vbb/showthread.php?t=466867 I still have not found a 100 % solution to this, but i use the microscope on my laptop and BB5 box on the PC! :P WBR |
11-22-2007, 17:09 | #19 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: Caribbean
Member: 98526 Status: Offline Thanks Meter: 12 | Quote:
I think this is the best solution, but i think also product supporter have to look a solution also between this. To be recognice in the same computer. Regards | |
11-28-2007, 22:35 | #23 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 54
Member: 49104 Status: Offline Sonork: 100.106791 Thanks Meter: 64 | Use The Hub..... I think yes, there will be confliction if u attached the mic just on other usb port or before the bb5 box, so use the hub of the bb5 box to be attached both in the same time..all will be ok, tested 100%.... |
12-10-2007, 18:05 | #24 (permalink) |
No Life Poster Join Date: Mar 2003
Member: 24435 Status: Offline Thanks Meter: 4 | bb5 microscope comes to me in pices like everyone else have received by DHL....but 3 nuts for down metal plate do not fit with holes...holes are bigger...and do not have flat head...just to inform you..."small" problem but extra efforts needed to be solved... |
12-13-2007, 03:41 | #25 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Computer Age: 41
Member: 154696 Status: Offline Thanks Meter: 16 | How can i unlock BB5 without Microscope ????? Always got this error help please......... ! PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 5050300014981890 Block 1: CLOSED Type 5 Data: 50503F Block 2: CLOSED Type 5 Data: 50503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... No microscope found! |
01-19-2008, 18:53 | #30 (permalink) |
Insane Poster Join Date: Aug 2005 Age: 42
Member: 168200 Status: Offline Thanks Meter: 0 | Hello people.. I need help with my microscope... When i connect the microscope my pc ask me for some drivers, so i download the drivers for this forum, but are corructed... What can i do... I have the BB5 Microscope i cant use it... Help me... Thank so much for your help... |
Bb5 Microscope Driver | Cibernetic | BB5BOX | 0 | 01-24-2008 17:26 |
BB5 Microscope TP DRIVER | Euan | BB5BOX | 1 | 01-15-2008 18:47 |
bb5 microscope driver | ps_tech | BB5BOX | 4 | 10-28-2007 06:21 |
Problem with combination BB5 microscope and BB5 Box | MobileserviceNL | BB5BOX | 7 | 10-11-2007 23:12 |
electronic microscope driver | ethem78 | Hardware Equipments for GSM | 0 | 12-24-2006 20:14 |
