11-14-2007, 15:44 | #1 (permalink) |
No Life Poster Join Date: Dec 2003
Member: 46387 Status: Offline Thanks Meter: 139 | bb5box big problem!!! Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 359537015069774 SP LOCK status: Config Key: 2261000000000000 Block 1: CLOSED Type 5 Data: 22610F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_359537015069774_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_359537015069774_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2261000000000000 Block 1: CLOSED Type 5 Data: 22610F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. |
11-14-2007, 17:52 | #3 (permalink) | |
Member: 46387 Status: Offline Thanks Meter: 139 | Quote:
11-14-2007, 19:48 | #4 (permalink) |
Banned Join Date: Nov 2007
Member: 632155 Status: Offline Thanks Meter: 0 | same problem like this http://forum.gsmhosting.com/vbb/member.php?u=632155 see bb5 box diagram. |
11-14-2007, 20:57 | #5 (permalink) | |
please post corect link,i think the problem is in the xilinx chip | |
11-14-2007, 21:09 | #6 (permalink) | |
Member: 632155 Status: Offline Thanks Meter: 0 | Quote:
http://forum.gsmhosting.com/vbb/show...05&postcount=5 BR | |
11-15-2007, 08:05 | #8 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
11-15-2007, 08:10 | #9 (permalink) |
Member: 46387 Status: Offline Thanks Meter: 139 | u are right,this is with delay because i tryed also with delay,but not work in any mode.the box is damaged.here is the corect log: ------ Operation: UNLOCK Date: 14-11-2007 Time: 16:15:05 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 359537015069774 SP LOCK status: Config Key: 2261000000000000 Block 1: CLOSED Type 5 Data: 22610F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_359537015069774_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_359537015069774_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2261000000000000 Block 1: CLOSED Type 5 Data: 22610F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. and another log from E65: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 354832012855878 SP LOCK status: Config Key: 2260100000000000 Block 1: CLOSED Type 5 Data: 22601F Block 2: CLOSED Type 5 Data: 22601F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-208_354832012855878_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-208_354832012855878_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2260100000000000 Block 1: CLOSED Type 5 Data: 22601F Block 2: CLOSED Type 5 Data: 22601F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. Last edited by =CostyGSM=; 11-15-2007 at 08:19. |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
Bb5box Big Probleme | cooloxf | BB5BOX | 52 | 02-01-2009 23:29 |
big big big big big problem with server | software zone | FuriousGold | 1 | 01-16-2008 17:25 |
my first unlocked phone with bb5box big thx hapy new year ... | senkron24 | BB5BOX | 0 | 12-31-2007 21:46 |
