11-13-2007, 21:22 | #1 (permalink) |
Major Poster Join Date: Nov 2006
Member: 398205 Status: Offline Thanks Meter: 1 | BB5Box Die? Or someone can fix? the box make unlock very very fast and i can't TP the open. The box dead 4 phones. i change the TP cable, the USB cable and the charger. Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 3************** SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_3**************_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. for shore the box dead but someone can help me to fix it? |
11-14-2007, 02:00 | #5 (permalink) |
Insane Poster Join Date: Mar 2004 Location: w.yorkshire Age: 52
Member: 57802 Status: Offline Thanks Meter: 4 | hi, first don't use acp12 without reading sticky thread or you will kill phones. second it sounds like the push button is stuck in or closed circuit. test with continuity tester on pin of needle and inside cable just before push button. if this is your problem either fix it or try changing delay settings to 5. this should give you time to connect testpoint carefully. good luck torbay |
11-14-2007, 19:50 | #9 (permalink) | |
Banned Join Date: Nov 2007
Member: 632155 Status: Offline Thanks Meter: 0 | Quote:
W910 error how fix this or when you fix this becouse I lost now credits !! !! !! | wgmmmx | Universalbox | 5 | 06-25-2008 20:54 |
mr rascal is true wath the bb5box died the fone????????? | carlosdamian | BB5BOX | 8 | 10-12-2007 21:05 |
to mr julvir or someone who can help me | johnnyml | Redbox | 0 | 05-12-2007 01:08 |
Error: Could not initialize GDFS access. can fix or not? | .::Gsmdenis::. | Cruiser Suite | 14 | 10-29-2005 08:30 |
UFS Team or someone who can help | Gsm_Man | UFS2 + UFS3-Tornadoflasher | 0 | 08-07-2004 23:19 |
