03-01-2008, 17:53 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | bb5box team i want help before i can touch test point fly and says all try have used up my supplers tell me that i don know how to used box i have paid good money fot that box bb5 team i need help |
03-01-2008, 18:06 | #2 (permalink) | |
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | Quote:
03-01-2008, 18:28 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Well seems like u are trying to say that every time u try to unlock a fone ask for conect TP and start unlocking w/o conecting TP automatically....if that's ur problem u must contact ur reseller for replacement BR, Tito Millo |
03-01-2008, 19:04 | #6 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
Did you evver unlocked any phone, or this happens on all phones with both DKU-2 and MiniUSB cables? | |
03-01-2008, 20:00 | #7 (permalink) |
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | i have bought new set of cable and same i borrow my friend cable and same ------ Operation: UNLOCK Date: 22-01-2008 Time: 15:38:59 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 15:39:48 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 15:40:05 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 15:50:49 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PM 308 Date: 22-01-2008 Time: 15:50:59 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-132_354804010965421_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia.__22_01_2008__15_51_14.bin ------ Operation: UNLOCK Date: 22-01-2008 Time: 15:51:25 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-132_354804010965421_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 15:53:15 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:25:24 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 22-01-2008 Time: 16:25:31 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 7 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-132_354804010965421_Locked_Keycnt_0_Fbuscnt_7__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 22-01-2008 Time: 16:26:19 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:26:39 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 22-01-2008 Time: 16:26:48 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-132_354804010965421_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:29:16 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 22-01-2008 Time: 16:29:27 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:29:40 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 22-01-2008 Time: 16:29:47 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-132_354804010965421_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:31:16 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 22-01-2008 Time: 16:31:25 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:31:41 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 22-01-2008 Time: 16:31:49 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-132_354804010965421_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:36:54 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 22-01-2008 Time: 16:37:08 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: UNLOCK Date: 22-01-2008 Time: 16:37:21 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-132_354804010965421_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:38:01 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 22-01-2008 Time: 16:38:09 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:38:23 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: RESET BOX USAGE Date: 22-01-2008 Time: 16:38:44 ------- Read BB5 Box serial number ... Authenticate with support server ... Authenticated BB5 Box Usage Reset OK ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:38:56 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 22-01-2008 Time: 16:39:03 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-132_354804010965421_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-132_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:39:39 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 22-01-2008 Time: 16:39:45 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 22-01-2008 Time: 16:39:59 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-132 Version: V_05wk47v34.1_05-10-06_RM-132_(c)_Nokia. IMEI: 354804010965421 SP LOCK status: Config Key: 3380500000000000 Block 1: CLOSED Type 5 Data: 33805F Block 2: CLOSED Type 5 Data: 35805F Block 3: CLOSED Type 5 Data: 360070 Block 4: CLOSED Type 5 Data: 352030 Block 5: CLOSED Type 5 Data: 342750 Block 6: CLOSED Type 5 Data: 374130 Block 7: CLOSED Type 5 Data: 363020 Block 8: CLOSED Type 5 Data: 36269F Block 9: CLOSED Type 5 Data: 310380 Block 10: CLOSED Type 5 Data: 34020F Block 11: CLOSED Type 5 Data: 372020 Block 12: CLOSED Type 5 Data: 73801F Block 13: CLOSED Type 5 Data: 70602F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:08:42 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 24-01-2008 Time: 11:09:02 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:09:36 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 24-01-2008 Time: 11:09:56 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Reset phone in TEST mode ... Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:10:22 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: FULL FACTORY Date: 24-01-2008 Time: 11:11:12 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:11:40 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 24-01-2008 Time: 11:12:10 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:12:28 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:12:44 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:13:18 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:13:26 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 11:14:13 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 22:59:02 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 22:59:48 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 23:00:04 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 23:03:37 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 24-01-2008 Time: 23:03:49 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 23:04:04 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 23:04:18 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 23:33:14 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PM 308 Date: 24-01-2008 Time: 23:33:24 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-146_356964011316137_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-146_(c)_Nokia.__24_01_2008__23_33_39.bin ------ Operation: UNLOCK Date: 24-01-2008 Time: 23:33:44 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-146_356964011316137_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-146_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 24-01-2008 Time: 23:34:38 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 23:35:08 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: WRITE PM 308 Date: 24-01-2008 Time: 23:35:26 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Reset phone in TEST mode ... Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 24-01-2008 Time: 23:36:09 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356964011316137 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310 |
03-01-2008, 20:04 | #8 (permalink) |
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | ------ Operation: UPDATE BOX FIRMWARE Date: 21-02-2008 Time: 16:25:51 ------- Read BB5 Box serial number ... Authenticate with support server ... Authenticated Update BB5 Box firmware ... BB5 Box firmware update OK ------ Operation: READ PHONE INFO Date: 21-02-2008 Time: 16:37:26 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.60_10-02-06_RM-78_(c)_Nokia IMEI: 359382002261070 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PM 308 Date: 21-02-2008 Time: 16:38:03 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.60_10-02-06_RM-78_(c)_Nokia IMEI: 359382002261070 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 4096 bytes Saving to file: RM-78_359382002261070_Locked_Keycnt_0_Fbuscnt_0__V_03 .60_10-02-06_RM-78_(c)_Nokia__21_02_2008__16_38_11.bin Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.60_10-02-06_RM-78_(c)_Nokia IMEI: 359382002261070 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_359382002261070_Locked_Keycnt_0_Fbuscnt_0__V_03 .60_10-02-06_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 21-02-2008 Time: 16:39:19 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.60_10-02-06_RM-78_(c)_Nokia IMEI: 359382002261070 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 21-02-2008 Time: 16:39:58 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.60_10-02-06_RM-78_(c)_Nokia IMEI: 359382002261070 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PHONE INFO Date: 24-02-2008 Time: 20:52:03 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 24-02-2008 Time: 20:52:15 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 SP LOCK status: Config Key: 3443423563583000 Block 1: CLOSED Type 5 Data: 358110 Block 2: CLOSED Type 5 Data: 346140 Block 3: CLOSED Type 5 Data: 352110 Block 4: CLOSED Type 5 Data: 366110 Block 5: CLOSED Type 5 Data: 360110 Block 6: CLOSED Type 5 Data: 344920 Block 7: CLOSED Type 5 Data: 356110 Block 8: CLOSED Type 5 Data: 376350 Block 9: CLOSED Type 5 Data: 365840 Block 10: CLOSED Type 5 Data: 354860 Block 11: CLOSED Type 5 Data: 342600 Block 12: CLOSED Type 5 Data: 338180 Block 13: CLOSED Type 5 Data: 348170 Block 14: CLOSED Type 5 Data: 358110 Block 15: CLOSED Type 5 Data: 346140 Block 16: CLOSED Type 5 Data: 352110 Block 17: CLOSED Type 5 Data: 366110 Block 18: CLOSED Type 5 Data: 360110 Block 19: CLOSED Type 5 Data: 344920 Block 20: CLOSED Type 5 Data: 356110 Block 21: CLOSED Type 5 Data: 376350 Block 22: CLOSED Type 5 Data: 365840 Block 23: CLOSED Type 5 Data: 354860 Block 24: CLOSED Type 5 Data: 342600 Block 25: CLOSED Type 5 Data: 338180 Block 26: CLOSED Type 5 Data: 348170 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PM 308 Date: 24-02-2008 Time: 20:52:26 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-115_359770005503722_Locked_Keycnt_0_Fbuscnt_0__V_0 6.10_16-02-07_RM-115_(c)_Nokia.__24_02_2008__20_52_41.bin ------ Operation: READ PHONE INFO Date: 24-02-2008 Time: 20:52:46 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 SP LOCK status: Config Key: 3443423563583000 Block 1: CLOSED Type 5 Data: 358110 Block 2: CLOSED Type 5 Data: 346140 Block 3: CLOSED Type 5 Data: 352110 Block 4: CLOSED Type 5 Data: 366110 Block 5: CLOSED Type 5 Data: 360110 Block 6: CLOSED Type 5 Data: 344920 Block 7: CLOSED Type 5 Data: 356110 Block 8: CLOSED Type 5 Data: 376350 Block 9: CLOSED Type 5 Data: 365840 Block 10: CLOSED Type 5 Data: 354860 Block 11: CLOSED Type 5 Data: 342600 Block 12: CLOSED Type 5 Data: 338180 Block 13: CLOSED Type 5 Data: 348170 Block 14: CLOSED Type 5 Data: 358110 Block 15: CLOSED Type 5 Data: 346140 Block 16: CLOSED Type 5 Data: 352110 Block 17: CLOSED Type 5 Data: 366110 Block 18: CLOSED Type 5 Data: 360110 Block 19: CLOSED Type 5 Data: 344920 Block 20: CLOSED Type 5 Data: 356110 Block 21: CLOSED Type 5 Data: 376350 Block 22: CLOSED Type 5 Data: 365840 Block 23: CLOSED Type 5 Data: 354860 Block 24: CLOSED Type 5 Data: 342600 Block 25: CLOSED Type 5 Data: 338180 Block 26: CLOSED Type 5 Data: 348170 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 24-02-2008 Time: 20:53:51 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 SP LOCK status: Config Key: 3443423563583000 Block 1: CLOSED Type 5 Data: 358110 Block 2: CLOSED Type 5 Data: 346140 Block 3: CLOSED Type 5 Data: 352110 Block 4: CLOSED Type 5 Data: 366110 Block 5: CLOSED Type 5 Data: 360110 Block 6: CLOSED Type 5 Data: 344920 Block 7: CLOSED Type 5 Data: 356110 Block 8: CLOSED Type 5 Data: 376350 Block 9: CLOSED Type 5 Data: 365840 Block 10: CLOSED Type 5 Data: 354860 Block 11: CLOSED Type 5 Data: 342600 Block 12: CLOSED Type 5 Data: 338180 Block 13: CLOSED Type 5 Data: 348170 Block 14: CLOSED Type 5 Data: 358110 Block 15: CLOSED Type 5 Data: 346140 Block 16: CLOSED Type 5 Data: 352110 Block 17: CLOSED Type 5 Data: 366110 Block 18: CLOSED Type 5 Data: 360110 Block 19: CLOSED Type 5 Data: 344920 Block 20: CLOSED Type 5 Data: 356110 Block 21: CLOSED Type 5 Data: 376350 Block 22: CLOSED Type 5 Data: 365840 Block 23: CLOSED Type 5 Data: 354860 Block 24: CLOSED Type 5 Data: 342600 Block 25: CLOSED Type 5 Data: 338180 Block 26: CLOSED Type 5 Data: 348170 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-115_359770005503722_Locked_Keycnt_0_Fbuscnt_0__V_0 6.10_16-02-07_RM-115_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3443423563583000 Block 1: CLOSED Type 5 Data: 358110 Block 2: CLOSED Type 5 Data: 346140 Block 3: CLOSED Type 5 Data: 352110 Block 4: CLOSED Type 5 Data: 366110 Block 5: CLOSED Type 5 Data: 360110 Block 6: CLOSED Type 5 Data: 344920 Block 7: CLOSED Type 5 Data: 356110 Block 8: CLOSED Type 5 Data: 376350 Block 9: CLOSED Type 5 Data: 365840 Block 10: CLOSED Type 5 Data: 354860 Block 11: CLOSED Type 5 Data: 342600 Block 12: CLOSED Type 5 Data: 338180 Block 13: CLOSED Type 5 Data: 348170 Block 14: CLOSED Type 5 Data: 358110 Block 15: CLOSED Type 5 Data: 346140 Block 16: CLOSED Type 5 Data: 352110 Block 17: CLOSED Type 5 Data: 366110 Block 18: CLOSED Type 5 Data: 360110 Block 19: CLOSED Type 5 Data: 344920 Block 20: CLOSED Type 5 Data: 356110 Block 21: CLOSED Type 5 Data: 376350 Block 22: CLOSED Type 5 Data: 365840 Block 23: CLOSED Type 5 Data: 354860 Block 24: CLOSED Type 5 Data: 342600 Block 25: CLOSED Type 5 Data: 338180 Block 26: CLOSED Type 5 Data: 348170 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 24-02-2008 Time: 20:55:18 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 24-02-2008 Time: 20:55:32 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 SP LOCK status: Config Key: 3443423563583000 Block 1: CLOSED Type 5 Data: 358110 Block 2: CLOSED Type 5 Data: 346140 Block 3: CLOSED Type 5 Data: 352110 Block 4: CLOSED Type 5 Data: 366110 Block 5: CLOSED Type 5 Data: 360110 Block 6: CLOSED Type 5 Data: 344920 Block 7: CLOSED Type 5 Data: 356110 Block 8: CLOSED Type 5 Data: 376350 Block 9: CLOSED Type 5 Data: 365840 Block 10: CLOSED Type 5 Data: 354860 Block 11: CLOSED Type 5 Data: 342600 Block 12: CLOSED Type 5 Data: 338180 Block 13: CLOSED Type 5 Data: 348170 Block 14: CLOSED Type 5 Data: 358110 Block 15: CLOSED Type 5 Data: 346140 Block 16: CLOSED Type 5 Data: 352110 Block 17: CLOSED Type 5 Data: 366110 Block 18: CLOSED Type 5 Data: 360110 Block 19: CLOSED Type 5 Data: 344920 Block 20: CLOSED Type 5 Data: 356110 Block 21: CLOSED Type 5 Data: 376350 Block 22: CLOSED Type 5 Data: 365840 Block 23: CLOSED Type 5 Data: 354860 Block 24: CLOSED Type 5 Data: 342600 Block 25: CLOSED Type 5 Data: 338180 Block 26: CLOSED Type 5 Data: 348170 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 SP LOCK status: Config Key: 3443423563583000 Block 1: CLOSED Type 5 Data: 358110 Block 2: CLOSED Type 5 Data: 346140 Block 3: CLOSED Type 5 Data: 352110 Block 4: CLOSED Type 5 Data: 366110 Block 5: CLOSED Type 5 Data: 360110 Block 6: CLOSED Type 5 Data: 344920 Block 7: CLOSED Type 5 Data: 356110 Block 8: CLOSED Type 5 Data: 376350 Block 9: CLOSED Type 5 Data: 365840 Block 10: CLOSED Type 5 Data: 354860 Block 11: CLOSED Type 5 Data: 342600 Block 12: CLOSED Type 5 Data: 338180 Block 13: CLOSED Type 5 Data: 348170 Block 14: CLOSED Type 5 Data: 358110 Block 15: CLOSED Type 5 Data: 346140 Block 16: CLOSED Type 5 Data: 352110 Block 17: CLOSED Type 5 Data: 366110 Block 18: CLOSED Type 5 Data: 360110 Block 19: CLOSED Type 5 Data: 344920 Block 20: CLOSED Type 5 Data: 356110 Block 21: CLOSED Type 5 Data: 376350 Block 22: CLOSED Type 5 Data: 365840 Block 23: CLOSED Type 5 Data: 354860 Block 24: CLOSED Type 5 Data: 342600 Block 25: CLOSED Type 5 Data: 338180 Block 26: CLOSED Type 5 Data: 348170 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-115_359770005503722_Locked_Keycnt_0_Fbuscnt_0__V_0 6.10_16-02-07_RM-115_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 500 miliseconds Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3443423563583000 Block 1: CLOSED Type 5 Data: 358110 Block 2: CLOSED Type 5 Data: 346140 Block 3: CLOSED Type 5 Data: 352110 Block 4: CLOSED Type 5 Data: 366110 Block 5: CLOSED Type 5 Data: 360110 Block 6: CLOSED Type 5 Data: 344920 Block 7: CLOSED Type 5 Data: 356110 Block 8: CLOSED Type 5 Data: 376350 Block 9: CLOSED Type 5 Data: 365840 Block 10: CLOSED Type 5 Data: 354860 Block 11: CLOSED Type 5 Data: 342600 Block 12: CLOSED Type 5 Data: 338180 Block 13: CLOSED Type 5 Data: 348170 Block 14: CLOSED Type 5 Data: 358110 Block 15: CLOSED Type 5 Data: 346140 Block 16: CLOSED Type 5 Data: 352110 Block 17: CLOSED Type 5 Data: 366110 Block 18: CLOSED Type 5 Data: 360110 Block 19: CLOSED Type 5 Data: 344920 Block 20: CLOSED Type 5 Data: 356110 Block 21: CLOSED Type 5 Data: 376350 Block 22: CLOSED Type 5 Data: 365840 Block 23: CLOSED Type 5 Data: 354860 Block 24: CLOSED Type 5 Data: 342600 Block 25: CLOSED Type 5 Data: 338180 Block 26: CLOSED Type 5 Data: 348170 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 24-02-2008 Time: 21:00:03 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 24-02-2008 Time: 21:00:16 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359770005503722 SP LOCK status: Config Key: 3443423563583000 Block 1: CLOSED Type 5 Data: 358110 Block 2: CLOSED Type 5 Data: 346140 Block 3: CLOSED Type 5 Data: 352110 Block 4: CLOSED Type 5 Data: 366110 Block 5: CLOSED Type 5 Data: 360110 Block 6: CLOSED Type 5 Data: 344920 Block 7: CLOSED Type 5 Data: 356110 Block 8: CLOSED Type 5 Data: 376350 Block 9: CLOSED Type 5 Data: 365840 Block 10: CLOSED Type 5 Data: 354860 Block 11: CLOSED Type 5 Data: 342600 Block 12: CLOSED Type 5 Data: 338180 Block 13: CLOSED Type 5 Data: 348170 Block 14: CLOSED Type 5 Data: 358110 Block 15: CLOSED Type 5 Data: 346140 Block 16: CLOSED Type 5 Data: 352110 Block 17: CLOSED Type 5 Data: 366110 Block 18: CLOSED Type 5 Data: 360110 Block 19: CLOSED Type 5 Data: 344920 Block 20: CLOSED Type 5 Data: 356110 Block 21: CLOSED Type 5 Data: 376350 Block 22: CLOSED Type 5 Data: 365840 Block 23: CLOSED Type 5 Data: 354860 Block 24: CLOSED Type 5 Data: 342600 Block 25: CLOSED Type 5 Data: 338180 Block 26: CLOSED Type 5 Data: 348170 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. i have unlocked this phone using mt box |
03-01-2008, 21:11 | #9 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 420862 Status: Offline Thanks Meter: 51 | yes this also happned with me i tried to unlock 6280 , upgraded to latest ver but gives error Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. unlocked this phone using mt box BB5 team wake up need help |
03-01-2008, 21:53 | #10 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: .::THE MATRIX::.
Member: 287370 Status: Offline Thanks Meter: 49 | You Can't Unlock your for now with BB5BOX ,Expect If you have Phone's Backup buy RPL or Waiting Reset 10/10 & 3/3 for your phone/version ! Loooook At This ! >> Quote:
Infinity Team I want help. After format no Network | IkaMazini | Infinity-Box | 20 | 06-29-2008 05:24 |
Infinity Team i want help. after format mobile dead | IkaMazini | Infinity-Box | 3 | 04-10-2008 14:41 |
N73 dead after Unlock fail.. plz. bb5box team help me.... | Abdur Rehman PK | BB5BOX | 7 | 02-29-2008 11:43 |
BB5box Team i need real help | S.O.S.G.S.M | BB5BOX | 11 | 11-14-2007 21:21 |
Please BB5Box team i need help | basim | BB5BOX | 2 | 09-27-2007 21:46 |
