Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 09-16-2007, 14:16   #1 (permalink)
MANOLE
Guest
Posts: n/a
Member:
** BB5BOX Updates Only Here - BB5 v0.0.4.1 - 3/3 10/10 FBUS counter reset **
Supported Versions for BB5 Box with Firmware version 1
http://www.bb5box.org/Supported_Versions_v1.html
http://www.bb5box.org/Supported_Versions_v1.pdf
Old 09-16-2007, 16:49   #2 (permalink)
MANOLE
Guest
Posts: n/a
Member:
Supported Versions for BB5 Box with Firmware version 2
http://www.bb5box.org/Supported_Versions_v2.html
http://www.bb5box.org/Supported_Versions_v2.pdf
Old 09-19-2007, 13:54   #3 (permalink)
Member: 588059
Thanks Meter: 47
Supported Versions for BB5 Box with Firmware version 3
http://www.bb5box.org/Supported_Versions_v3.html
http://www.bb5box.org/Supported_Versions_v3.pdf
Old 09-27-2007, 23:14   #4 (permalink)
Member: 588059
Thanks Meter: 47
Supported Versions for BB5 Box with Firmware version 4
http://www.bb5box.org/Supported_Versions_v4.html
http://www.bb5box.org/Supported_Versions_v4.pdf
The Following 3 Users Say Thank You to BB5box.org For This Useful Post:
Old 09-27-2007, 23:14   #5 (permalink)
Member: 588059
Thanks Meter: 47
Supported Versions for BB5 Box with Firmware version 5
http://www.bb5box.org/Supported_Versions_v5.html
http://www.bb5box.org/Supported_Versions_v5.pdf
Old 10-05-2007, 23:34   #6 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.2.2:
- Added automatic write backup when perform Unlocking (file with lowest FBUS counter is auto selected)
- Added option to enable/disable automatic write of PM 308 when perform Unlocking
- Added option to enable/disable Full Factory Settings when perform Unlock
- Added filtered selection when Write PM 308 (allow select only files for current connected phone)
- All current settings is saved in configuration file
- Switch phone in Test Mode when perform Full Factory Settings and Unlocking (in case if phone is in Local Mode)
- All messages are saved in log file (BB5_Box_log.txt in current directory)
- Removed Win-XP not allowed characters from saved file names ( e.g. phones with IMEI 123...?? )
Supported Versions for BB5 Box with Firmware version 6
http://www.bb5box.org/Supported_Versions_v6.html
http://www.bb5box.org/Supported_Versions_v6.pdf
The Following User Says Thank You to BB5box.org For This Useful Post:
Old 10-06-2007, 12:49   #7 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.2.3:
- Added progress bar for Read PM 308, Autobackup and BOX Firmware Update
- Added "phone ping" when waiting for testpoints connections
- Improved error handling when sending SP Code for unlock
Old 10-09-2007, 04:20   #8 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.2.4:
- Added option to enable/disable "phone ping" when waiting for testpoints connections
Supported Versions for BB5 Box with Firmware version 7
http://66.199.236.202/bb5box/index.p...d=18&Itemid=35
http://www.bb5box.org/Supported_Versions_v7.html
http://www.bb5box.org/Supported_Versions_v7.pdf
Old 10-09-2007, 13:56   #9 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.2.5:
- Added automatic frame with testpoint details for connected phone when unlocking
(new window popup when software ask to connect testpoints and disapear when testpoint are connected)
- Corrected bug from v0.0.2.4 when read version from some models and report "Not supported model/version" (e.g. N73)
Direct download links:
Software BB5 Box v0.0.2.5 with HIGH resolution testpoint images (83 MB):
BB5_v025_HiRes.zip - Server 1 (USA)
BB5_v025_HiRes.zip - Server 2 (USA)
Software BB5 Box v0.0.2.5 with LOW resolution testpoint images (6 MB):
BB5_v025_LowRes.zip - Server 1 (USA)
BB5_v025_LowRes.zip - Server 2 (USA)
Old 10-19-2007, 05:32   #10 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.2.6:
Software BB5 Box v0.0.2.6 with HIGH resolution testpoint images (83 MB):
BB5_v026_HiRes.zip - Server 1 (USA)
BB5_v026_HiRes.zip - Server 2 (USA)
Software BB5 Box v0.0.2.6 with LOW resolution testpoint images (6 MB):
BB5_v026_LowRes.zip - Server 1 (USA)
BB5_v026_LowRes.zip - Server 2 (USA)
Supported Versions for BB5 Box with Firmware version 8
http://www.bb5box.org/Supported_Versions_v8.html
http://www.bb5box.org/Supported_Versions_v8.pdf
Old 11-15-2007, 06:42   #11 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.2.7:
- Improved unlock procedure agains wrong testpoint location touch
- Added model/version unlock support check when Read Info
- Integrated USB microscope popup watch window
- Added enable/disable option for popup window with testpoints details
- Added enable/disable option for microscope view popup window
- Save testpoints details popoup window position and size
- Save microscope view popoup window position and size
- Save current microscope USB device selection
Software BB5 Box v0.0.2.7 - EXE file only:
BB5_v027_EXE_Only.zip - Server 1 (USA)
BB5_v027_EXE_Only.zip - Server 2 (USA)
Old 11-30-2007, 00:48   #12 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.2.8:
- Added Full Factory function even for unlocked phones
- Added selection of flash type (when phone model require this) when Read Info
- Removed a bug who not allow start software when card usage reached 100%
Software BB5 Box v0.0.2.8 - EXE file only:
BB5_v028_EXE_Only.zip - Server 1 (USA)
BB5_v028_EXE_Only.zip - Server 2 (USA)
Supported Versions for BB5 Box with Firmware version 9
http://www.bb5box.org/Supported_Versions_v9.html
http://www.bb5box.org/Supported_Versions_v9.pdf
Old 12-15-2007, 07:22   #13 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.2.9:
- Unlock procedure reverted as in version v0.0.2.6
- Default settings changed to no use microscope and not ping mobile
Software BB5 Box v0.0.2.9 - EXE file only:
BB5_v029_EXE_Only.zip - Server 1 (USA)
BB5_v029_EXE_Only.zip - Server 2 (USA)
Supported Versions for BB5 Box with Firmware version 10
http://www.bb5box.org/Supported_Versions_v10.html
http://www.bb5box.org/Supported_Versions_v10.pdf
Old 12-18-2007, 17:52   #14 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box v0.0.3.0:
Software BB5 Box v0.0.3.0 - EXE file only:
BB5_v030_EXE_Only.zip - Server 1 (USA)
BB5_v030_EXE_Only.zip - Server 2 (USA)
Supported Versions for BB5 Box with Firmware version 11
http://www.bb5box.org/Supported_Versions_v11.html
http://www.bb5box.org/Supported_Versions_v11.pdf
Old 12-20-2007, 23:26   #15 (permalink)
Member: 588059
Thanks Meter: 47
Software BB5 Box Updater:
- Allow to update any firmware version (older or newer) on box
- Use this soft before you want to use any older BB5 Box software
- All older software versions are available for download on our page (http://www.bb5box.org or http://www.bb5box.hk)
- In same Download page is specified each BB5 software what firmware require inside box
BB5_Updater.zip - Server 1
BB5_Updater.zip - Server 2
The Following 2 Users Say Thank You to BB5box.org For This Useful Post:
Help BB5 v0.0.4.1 Tequilas BB5BOX 9 04-19-2008 12:06
** Discussion about BB5 v0.0.4.1- 3/3 10/10 FBUS counter reset abdooo_19888 BB5BOX 62 04-03-2008 17:31
** Discussion about BB5 v0.0.4.0 - 3/3 10/10 FBUS counter reset ** snsoftkiller BB5BOX 62 03-25-2008 14:03
Supported Fbus Counter Reset Phones (3/3 10/10) chiragp AdvanceUFS 8 03-17-2008 10:40
DISCUSSION: BB5BOX Update BB5 v0.0.3.5 - added 2 unlock methods shahzaadbutt BB5BOX 90 01-27-2008 17:55
Page generated in 0.40168 seconds with 8 queries
