01-09-2008, 00:17 | #16 (permalink) |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | - Added unlock support for phones with Cable counter 10 from 10 tryes (FBUS 10/10) Software BB5 Box v0.0.3.1 - EXE file only: BB5_v031_EXE_Only.zip - Server 1 (USA) BB5_v031_EXE_Only.zip - Server 2 (USA) |
01-11-2008, 19:34 | #17 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.3.2: Software BB5 Box v0.0.3.2 - EXE file only: BB5_v032_EXE_Only.zip - Server 1 (USA) BB5_v032_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 12 http://www.bb5box.org/Supported_Versions_v12.html http://www.bb5box.org/Supported_Versions_v12.pdf Last edited by BB5box.org; 03-01-2008 at 14:18. |
01-14-2008, 10:19 | #18 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.3.3: Software BB5 Box v0.0.3.3 - EXE file only: BB5_v033_EXE_Only.zip - Server 1 (USA) BB5_v033_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 13 http://www.bb5box.org/Supported_Versions_v13.html http://www.bb5box.org/Supported_Versions_v13.pdf http://66.199.236.202/bb5box/index.p...d=18&Itemid=35 Last edited by BB5box.org; 01-14-2008 at 11:35. |
01-19-2008, 07:00 | #19 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.3.4: Software BB5 Box v0.0.3.4 - EXE file only: BB5_v034_EXE_Only.zip - Server 1 (USA) BB5_v034_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 14 http://www.bb5box.org/Supported_Versions_v14.html http://www.bb5box.org/Supported_Versions_v14.pdf http://66.199.236.202/bb5box/index.p...d=18&Itemid=35 |
01-20-2008, 13:02 | #20 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.3.5: - Added 2 methods for unlock procedure (each have own direct button) Software BB5 Box v0.0.3.5 - EXE file only: BB5_v035_EXE_Only.zip - Server 1 (USA) BB5_v035_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 15 http://www.bb5box.org/Supported_Versions_v15.html http://www.bb5box.org/Supported_Versions_v15.pdf http://66.199.236.202/bb5box/index.p...d=18&Itemid=35 Some details about what means Method1, Method 2: Method 2 was used from software version 0.0.2.6 to 0.0.3.0 Method 1 was used on all other software versions. Some users reported they have success and work more good Method 2 (we read forum and based this on reported software versions). Some other users reported the all other versions (Method 1) worked well or more good. So, we included both 2 methods now. Try one method, if not unlock can try the other one. It also depends on phone models, so on some phones could work better Method 1 and on some other phones could work better Method 2. What exactly is the difference is hard to explain here, mainly is about tunning timing values and at exactly what time (regarding to clock front signal) data is sampled, also if data is sampled on rising or falling edge of the clock. Something like this graphic (we can change timings inside CPLD also clock edge, rising or falling): http://en.wikipedia.org/wiki/Image:F...ld_Toutput.svg All this timings in real world (when you perform unlock) could differ from one flash chip to another. Also this timings is influenced of capacitance loading values over CLK and DATA lines (= length of TP wires, position of TP wires, GND connection point). Last edited by BB5box.org; 01-20-2008 at 19:09. |
02-01-2008, 01:31 | #21 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.3.6: Software BB5 Box v0.0.3.6 - EXE file only: BB5_v036_EXE_Only.zip - Server 1 (USA) BB5_v036_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 16 http://www.bb5box.org/Supported_Versions_v16.html http://www.bb5box.org/Supported_Versions_v16.pdf http://66.199.236.202/bb5box/index.p...d=18&Itemid=35 Testpoint details for N77 and N92 is here: http://www.bb5box.org/N77.jpg http://www.bb5box.org/N92.jpg We will made soon more clear and high resolution details. Last edited by BB5box.org; 02-01-2008 at 01:54. |
02-06-2008, 06:02 | #22 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.3.7: Software BB5 Box v0.0.3.7 - EXE file only: BB5_v037_EXE_Only.zip - Server 1 (USA) BB5_v037_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 17 http://www.bb5box.org/Supported_Versions_v17.html http://www.bb5box.org/Supported_Versions_v17.pdf http://66.199.236.202/bb5box/index.p...d=18&Itemid=35 High resolution testpoint details for 3500c is here: http://www.bb5box.org/3500.jpg Testpoint details for N95-6 (RM-160) is same with N95-1 (RM-159). Also added Dissasembly Videos on www.bb5box.org page (under Video menu) Last edited by BB5box.org; 02-06-2008 at 06:19. |
02-26-2008, 22:07 | #23 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.3.8: Software BB5 Box v0.0.3.8 - EXE file only: BB5_v038_EXE_Only.zip - Server 1 (USA) BB5_v038_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 18 http://www.bb5box.org/Supported_Versions_v18.html http://www.bb5box.org/Supported_Versions_v18.pdf http://66.199.236.202/bb5box/index.p...d=18&Itemid=35 |
03-01-2008, 14:12 | #24 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.4.0: - added support for 3/3 10/10 FBUS counter reset (more models will come soon) - added support for more options for data testpoint (AD0/AD1 selection for Nokia 6280/6288) - improved whole unlock procedure speed time Software BB5 Box v0.0.4.0 - EXE file only: BB5_v040_EXE_Only.zip - Server 1 (USA) BB5_v040_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 19 http://www.bb5box.org/Supported_Versions_v19.html http://www.bb5box.org/Supported_Versions_v19.pdf http://www.bb5box.org/index742a.html New updated 6280/6288 testpoint details: http://www.bb5box.org/6280_6288.jpg |
The Following User Says Thank You to BB5box.org For This Useful Post: |
03-29-2008, 23:30 | #25 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | Software BB5 Box v0.0.4.1: - added 3/3 10/10 FBUS counter reset for following models/versions: 5200 v05.51 (SEC ATB, SEC ATD) 5200b v05.51 (SEC ATB, SEC ATD) 6280 v06.43 (SEC ETA, Spansion) 6300 v06.01 (SEC ATB, SEC ATD, Spansion) 6300b v06.01 (SEC ATB, SEC ATD, Spansion) - removed "Orange theme" bug from v 0.0.4.0 Software BB5 Box v0.0.4.1 - EXE file only: BB5_v041_EXE_Only.zip - Server 1 (USA) BB5_v041_EXE_Only.zip - Server 2 (USA) |
The Following 3 Users Say Thank You to BB5box.org For This Useful Post: |
Help BB5 v0.0.4.1 | Tequilas | BB5BOX | 9 | 04-19-2008 12:06 |
** Discussion about BB5 v0.0.4.1- 3/3 10/10 FBUS counter reset | abdooo_19888 | BB5BOX | 62 | 04-03-2008 17:31 |
** Discussion about BB5 v0.0.4.0 - 3/3 10/10 FBUS counter reset ** | snsoftkiller | BB5BOX | 62 | 03-25-2008 14:03 |
Supported Fbus Counter Reset Phones (3/3 10/10) | chiragp | AdvanceUFS | 8 | 03-17-2008 10:40 |
DISCUSSION: BB5BOX Update BB5 v0.0.3.5 - added 2 unlock methods | shahzaadbutt | BB5BOX | 90 | 01-27-2008 18:55 |
