10-31-2007, 23:21 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Caribbean
Member: 98526 Status: Offline Thanks Meter: 12 | Nokia E 62 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-88 Version: Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia._ IMEI: 357951000343320 SP LOCK status: Config Key: 7340200000000000 Block 1: CLOSED Type 5 Data: 73402F Block 2: CLOSED Type 5 Data: 73403F Block 3: CLOSED Type 5 Data: 73401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 8 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-88_357951000343320_Locked_Keycnt_0_Fbuscnt_8__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-88_357951000343320_Locked_Keycnt_0_Fbuscnt_0__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7340200000000000 Block 1: CLOSED Type 5 Data: 73402F Block 2: CLOSED Type 5 Data: 73403F Block 3: CLOSED Type 5 Data: 73401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. |
11-01-2007, 00:36 | #2 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: ...Argentina
Member: 225513 Status: Offline Thanks Meter: 23 | try new Quote:
Writer backup PM, & Try again | |
11-02-2007, 08:17 | #6 (permalink) |
No Life Poster Join Date: May 2001 Location: Hungary Age: 55
Member: 4695 Status: Offline Thanks Meter: 15 | Hi, this file must be rewrite: RM-88_357951000343320_Locked_Keycnt_0_Fbuscnt_0__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin and the Response byte: 55 is wrong GND connection , remove the crocodile-wire or reconnect near the CPU! BR , Keni |
11-02-2007, 15:04 | #7 (permalink) | |
Member: 98526 Status: Offline Thanks Meter: 12 | Quote:
Ok thanks man i will post results regards | |
11-03-2007, 00:58 | #8 (permalink) | |
1. I take the Gnd Connection, remove the crocodile -wire also reconect it from near the cpu, NO RESULTS Response 55 2. I rewrite the same file but also the same Unlock fail Pls help | |
11-06-2007, 18:44 | #9 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: Z3x
Member: 98342 Status: Offline Sonork: 1641338 Thanks Meter: 19 | Quote:
The same problem with me always get response 55 anyone have done unlock this E62 phone and post the result thanks | |
11-06-2007, 21:39 | #10 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | very lucky after cutting grill pc on i unlock one pcs in 3 pcs two dead after cutting shield phone dead only cutting shield |
nokia SS-62 ,CU4 | pol98 | Wanted Products | 0 | 04-12-2009 22:25 |
nokia E 62 | shammysaini | Nokia Hardware & Hardware Repair | 1 | 11-24-2008 09:14 |
nokia E 62 joystick | gulam khadir | ipmart WebShop | 0 | 10-25-2008 12:35 |
nokia e 62 | gulam khadir | Nokia Base Band 5 ( BB-5 ) | 0 | 10-22-2008 10:24 |
nokia e 62 | gulam khadir | Nokia Base Band 5 ( BB-5 ) | 0 | 10-21-2008 09:32 |
