02-26-2008, 21:39 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Egypt Age: 35
Member: 629039 Status: Offline Sonork: 100.112945 Thanks Meter: 847 | Dead N73 After Connect Only To Box I Only Connect N73 To My Box No Read Info It Was So Ok No Info No Info I Check My Phone I Found It's Dead Now I Didn't Toch Tp Area Or Any Thing In The Phone Plz Help Me ???? |
02-26-2008, 21:45 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Fone was ok be4 u disassembly it and conect it may u toched any diode with neddle and that me a short circuit and that killed ur fone thats the other option but u must try to flash it and post log from flashing BR, Tito Millo |
02-27-2008, 01:21 | #4 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: I'm back to business
Member: 184793 Status: Offline Sonork: 100.1574609 Thanks Meter: 45 | Quote:
Br LordMen007 | |
02-27-2008, 09:57 | #5 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | bb5 box my 2 set kill here is i properly desamble and properly conect box and set and i read info and press unlock method 1 and here is loge and set kill bb5 box ------ Operation: READ PHONE INFO Date: 24-02-2008 Time: 13:29:11 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia. IMEI: 359738004795995 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia. IMEI: 359738004795995 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_359738004795995_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v28.1_22-06-06_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 i many try bur set not fount test pont its ok100% not damaged testpoint but set not power on not boot and i many phone unlock this box but 2 set my kill this box n73 & 6280 and here is another ser kill loge this box 6280 kill bb5 box ------ Operation: READ PHONE INFO Date: 16-02-2008 Time: 13:43:55 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.36_05-12-05_RM-78_(c)_Nokia IMEI: 357603007744030 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PHONE INFO Date: 16-02-2008 Time: 13:50:44 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.36_05-12-05_RM-78_(c)_Nokia IMEI: 357603007744030 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.36_05-12-05_RM-78_(c)_Nokia IMEI: 357603007744030 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_357603007744030_Locked_Keycnt_0_Fbuscnt_0__V_03 .36_05-12-05_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 pliz y the box phone kill raskal note this point and next update fixed this bug |
02-27-2008, 10:17 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Always Here Age: 37
Member: 333494 Status: Offline Sonork: 100.1607053 Thanks Meter: 190 | my frend box. not kill the phone you kill him use serch button this problem postet many times http://67.15.194.130/vbb/showthread....hlight=bb5+box |
02-27-2008, 10:27 | #7 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | i hope this box is kill my phone but y ? this eroor show ERROR: 11160001 ERROR: 30020091 where is i wrong explian me ??????????????????????????????????????????/ |
02-27-2008, 12:43 | #8 (permalink) |
Member: 629039 Status: Offline Sonork: 100.112945 Thanks Meter: 847 | Hi Again My Phone With Ok Before Dessimple And After Dessemple I Connect It To My Cable Then Try To Get Info No Info And Fone Is Dead May Be More Power Come Into My Phone With Try To Reflash And Bost Result |
02-27-2008, 13:59 | #9 (permalink) |
Member: 629039 Status: Offline Sonork: 100.112945 Thanks Meter: 847 | NAVEED I DONT SAY THAT BB5 IS THE BEST THIS HAPPEN BEFORE ANY ORDER THIS IS FLASHING LOG WITH JAF FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_4.0736.3.2.1_western_C00_PRD_cc.fpsx PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_rofx_4.0736.3.2.1_PRD.V11 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_userarea_4.0736.3.2.1.U01 APE Variant file: NONE Languages in ppm: English,Simpl Chinese Manual mode selected, version can't be checked! Booting phone... Error sync the phone... Booting phone... Error sync the phone... Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 44018EB7ED335DD66926389BEA2D8D58B55B3BB1 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0C60010F79F80154A9D7CB871E9FCB050A22F623 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready Error in MSG id... Error in cmt get id... Manual mode selected, version can't be checked! Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 44018EB7ED335DD66926389BEA2D8D58B55B3BB1 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0C60010F79F80154A9D7CB871E9FCB050A22F623 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.1F.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC -> ST APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 17 seconds... Sending CNF Data... Erasing... Operation took 0 minutes 46 seconds... Writing... Stage 1 Sending APE HASH for KEYS Sending CMT HASH for NOLO Sending APE HASH for X-LOADER Sending CMT HASH for KEYS Sending APE HASH for PRIMAPP Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC Sending APE HASH for SOS+LOADER Sending CMT PUB KEYS... Sending CMT HASH for UPDAPP Sending APE HASH for SOS*UPDAPP Sending CMT HASH for ADL Sending CMT HASH for DSP0 Sending APE HASH for SOS+UZIP Sending APE PUB KEYS... Sending APE HASH for PASUBTOC Sending APE HASH for ADL Sending APE HASH for SOS+XZIP Sending APE HASH for SOS*CORE Sending CMT HASH for MCUSW Stage 2 Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 44018EB7ED335DD66926389BEA2D8D58B55B3BB1 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0C60010F79F80154A9D7CB871E9FCB050A22F623 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.1F.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC -> ST APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 11 seconds... Sending CNF Data... Stage 1 Stage 2 Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 44018EB7ED335DD66926389BEA2D8D58B55B3BB1 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0C60010F79F80154A9D7CB871E9FCB050A22F623 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.1F.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC -> ST APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 12 seconds... Sending CNF Data... Stage 1 Stage 2 FAST MODE finish! Operation took 4 minutes 51 seconds... Reseting phone... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_rofx_4.0736.3.2.1_PRD.V11 Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 44018EB7ED335DD66926389BEA2D8D58B55B3BB1 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0C60010F79F80154A9D7CB871E9FCB050A22F623 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.1F.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC -> ST APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 12 seconds... Sending CNF Data... Erasing... Operation took 0 minutes 1 seconds... Writing... Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 44018EB7ED335DD66926389BEA2D8D58B55B3BB1 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0C60010F79F80154A9D7CB871E9FCB050A22F623 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.1F.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC -> ST APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 12 seconds... Sending CNF Data... FAST MODE finish! Operation took 2 minutes 56 seconds... Reseting phone... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_userarea_4.0736.3.2.1.U01 Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 44018EB7ED335DD66926389BEA2D8D58B55B3BB1 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0C60010F79F80154A9D7CB871E9FCB050A22F623 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.1F.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC -> ST APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 12 seconds... Erasing... Operation took 0 minutes 1 seconds... Writing... Operation took 1 minutes 9 seconds... Reseting phone... Done! Total time: 10 Minutes, 30 Seconds DCT4/BB5 counter: 35 After flash processing... Waiting for phone to boot... Reading... Failed! Aborting!...IMEI |
02-27-2008, 14:15 | #10 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | bb5box raskal my 2 set kill bb5 box my 2 set kill here is i properly desamble and properly conect box and set and i read info and press unlock method 1 and here is loge and set kill bb5 box ------ Operation: READ PHONE INFO Date: 24-02-2008 Time: 13:29:11 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia. IMEI: 359738004795995 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia. IMEI: 359738004795995 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_359738004795995_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v28.1_22-06-06_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 i many try bur set not fount test pont its ok100% not damaged testpoint but set not power on not boot and i many phone unlock this box but 2 set my kill this box n73 & 6280 and here is another ser kill loge this box 6280 kill bb5 box ------ Operation: READ PHONE INFO Date: 16-02-2008 Time: 13:43:55 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.36_05-12-05_RM-78_(c)_Nokia IMEI: 357603007744030 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: READ PHONE INFO Date: 16-02-2008 Time: 13:50:44 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.36_05-12-05_RM-78_(c)_Nokia IMEI: 357603007744030 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.36_05-12-05_RM-78_(c)_Nokia IMEI: 357603007744030 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_357603007744030_Locked_Keycnt_0_Fbuscnt_0__V_03 .36_05-12-05_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 pliz y the box phone kill raskal note this point and next update fixed this bug (bb5box killing phone ) (Mt is good 100%) |
02-27-2008, 14:18 | #11 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
my bb5 box does not dessasably any phone automatic, this make the customer and if the customer kill phone due wrong dessabling than i also can not help. belive me, my bb5 ca not kill phone, the one who kill phones are the customers which not follow the exact procedures to work with. we have many satisfied users, and this is why our box is the most popular bb5 unlocker on the market. B.R., Raskal | |
02-27-2008, 14:21 | #12 (permalink) | |
02-27-2008, 14:34 | #13 (permalink) |
Member: 563 Status: Offline Thanks Meter: 22,328 | @sagib2009 bro, u really must learn first to use the box, or to go to some one who have this box or another box wich use tp for unlock and watch and learn little bit how to unlock with it. To work with this box is easy for a good technician, but little bit hard for some not very experienced ppl. B.R., Raskal |
n73 after flash only nokia | md jawad | Nokia Hardware & Hardware Repair | 14 | 11-13-2009 07:53 |
n73 after flash only nokia | dheeraj_b | HWK | 6 | 02-19-2009 12:43 |
dead GX25 after connecting 9v | EDV11 | Sharp | 0 | 08-01-2006 12:49 |
