01-01-2008, 14:58 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 43
Member: 61557 Status: Offline Thanks Meter: 130 | E61 First try Fail 2nd Counter limit reached. Please write PM 308 backup. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: 356211002747486 SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 20810F Block 3: CLOSED Type 5 Data: 64710F Block 4: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-89_356211002747486_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. ------ Operation: UNLOCK Date: 01-01-2008 Time: 11:29:35 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: 356211002747486 SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 20810F Block 3: CLOSED Type 5 Data: 64710F Block 4: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-89_356211002747486_Locked_Keycnt_0_Fbuscnt_10__V_3 .0533.6_31-10-06_RM-89_(c)_Nokia..bin Counter limit reached. Please write PM 308 backup. after trying first it failed and at the 2nd time it says "Counter limit reached. Please write PM 308 backup. i tried to write again the auto pm backups ------ Operation: WRITE PM 308 Date: 01-01-2008 Time: 11:30:18 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: 356211002747486 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK same problem occured? "Operation: UNLOCK Date: 01-01-2008 Time: 11:30:58 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: 356211002747486 SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 20810F Block 3: CLOSED Type 5 Data: 64710F Block 4: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-89_356211002747486_Locked_Keycnt_0_Fbuscnt_10__V_3 .0533.6_31-10-06_RM-89_(c)_Nokia..bin already exist Counter limit reached. Please write PM 308 backup." Whats seems to be the problem here? Manole, Dani, Raskal Guys what you think is the problem here? BR DaWizard |
The Following User Says Thank You to DaWizard For This Useful Post: |
01-01-2008, 15:31 | #2 (permalink) |
Insane Poster Join Date: May 2007
Member: 505284 Status: Offline Thanks Meter: 4 | find the file and try write it RM-89_356211002747486_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin |
The Following User Says Thank You to RaMCES For This Useful Post: |
can I write PM 308 backup from other phone for counter reset? | snowtown | BB5BOX | 4 | 04-20-2008 17:12 |
Counter limit reached. Please write PM 308 backup | toto2 | BB5BOX | 3 | 04-11-2008 11:03 |
6300 with (Counter limit reached. Please write PM 308 backup.) | Mounir | BB5BOX | 1 | 01-25-2008 11:56 |
Counter limit reached? Even though backup written | James_S | BB5BOX | 9 | 09-29-2007 00:30 |
CGI-limits reached, please try again later! | davieb | Board, Server and Login Problems/Support | 2 | 01-25-2002 23:29 |
