03-27-2008, 22:27 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: egypt Age: 47
Member: 127767 Status: Offline Sonork: 100.1646527 Thanks Meter: 6 | E65 Plz Help Me Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 354832018680429 SP LOCK status: Config Key: 2600100000000000 Block 1: CLOSED Type 5 Data: 26001F Block 2: CLOSED Type 5 Data: 26001F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-208_354832018680429_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 |
03-27-2008, 22:36 | #2 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Millionaire Club ™
Member: 487562 Status: Offline Thanks Meter: 111 | Put on "test connection with phone" (coz its easy to interupt connection with touchin wrong tp's) im using unlock vr.2 nd most important: resp byte 55 is meanin that phone is not grounded corectly,,,,, (EXPLAINED MANY TIMES) |
E65 plz help me | the jinnah | Nokia Hardware & Hardware Repair | 5 | 07-05-2012 15:14 |
plz help me | lloydgsm | FuriousGold | 3 | 03-29-2010 20:08 |
plz help me its urgent | lloydgsm | SETool2 | 2 | 03-29-2010 17:45 |
plz help me | lloydgsm | SETool2 | 6 | 03-29-2010 13:10 |
unlock problem with ub E65..PLZ HELP ME... | diljan_07 | Universalbox | 4 | 04-28-2008 16:28 |
