![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2004 Age: 44
Member: 64311 Status: Offline Thanks Meter: 110 | Error: can not detect phone on fbus interface 1. changed all usb cable 2. changed 4 different vergin pc 3. bb5box update ok 4. box connection with sw ok 5. tryed to reset eeprom but not connecting in mprog 6. tryed 7.5k resistor between two wires. 7. repeated procedure 100 times. 8. install and uninstall drivers in each systems. what the hell is problem ..anything other practice left? hoping for good and fast support...thanks to gorr for support but still not able to set problem |
![]() | #3 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: lost in a supermarket
Member: 239318 Status: Offline Thanks Meter: 51 | Quote:
is it with all phones or just with one pic? phone anyway connected to box turns on? because i had ome 6280 with this problem but it had a fault and even if powered on and in test mode box could not see it. because of fault i used it for other things.. | |
![]() | #5 (permalink) |
Member: 64311 Status: Offline Thanks Meter: 110 | Problem is with n5300...not checked other phones with this box... todays effort. 1. applied direct power connection from nokia battery. 2. change diff. ground location. 3. phone entering test mode now...but still bloody fbus interface not found Anyone else from support? |
![]() | #6 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2003 Location: Kakanien Age: 55
Member: 45247 Status: Offline Thanks Meter: 49 | Quote:
read manual .there is no ground connection during reading . | |
![]() | #7 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2002 Location: Earth Age: 60
Member: 9274 Status: Offline Thanks Meter: 79 | Quote:
hi, try to make factory reset first, before you use the BB5Box ![]() br Kole64 | |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: anywhere there is freedom Age: 47
Member: 106700 Status: Offline Thanks Meter: 47 | hey i got a 5300 with similar prob today. i unlock many but this rm 146 ver 3.92 is not being detected by fbus. phone is ok. what other solution can be proposed? Phone is in: Test mode Model: RM-146 ( 5300) V 03.92/13-10-06/RM-146 (c) Nokia. Production serial number PPA207861 Product code 0515424 Module code 0202938 Basic production code 0530535 Flash code Order number Long production SN MCU SW V 03.92/13-10-06/RM-146/(c) Nokia. HW 2502 PCI RFIC 17211721 DSP pb06w14v21 PPM V 03.92/13-10-06/RM-146/(c) Nokia. /C BT MCM 06cc-P8.0 Retu 32 Tahvo 53 Content Pack Content: meteor_ie/V 03.92/13-10-06/RM-146/(c) Nokia. // IMEI: 354564016300441 WARNING: VPP pin is not connected, disabling VPP. Phone is in: Test mode Full Factory Set...OK factory default does not help! Last edited by ashvin; 10-13-2007 at 09:25. |
![]() | #11 (permalink) | |
hi, power the phone , make factory defaults direct with phone and then use the BB5Box! br Kole64 | |
![]() | #12 (permalink) |
Member: 106700 Status: Offline Thanks Meter: 47 | i just check usb connection of phone; its a complete mess up. somebody try to repair something there. now its is almost impossible to change it as the sloder on board has been removed. is there any other place i can take connection now? |
hi plz help me out this prob..N73 HELP ME ! Error: can not detect phone on fbus inter | gsmshahrayar | BB5BOX | 3 | 11-01-2007 17:47 |
N73 HELP ME ! Error: can not detect phone on fbus interface" | cpsite | BB5BOX | 15 | 11-01-2007 11:43 |
ERROR: Cannot detect phone on FBUS interface | gsm_connections | BB5BOX | 11 | 10-24-2007 21:04 |
Here is one solution for: "Error: can not detect phone on fbus interface" | x_gsm | BB5BOX | 2 | 10-24-2007 09:39 |
ALL DKU2 Cable problem here, i have managed. can not detect phone on fbus interface | berwan | BB5BOX | 6 | 10-13-2007 14:01 |
