01-11-2008, 09:06 | #1 (permalink) |
Freak Poster Join Date: Aug 2005
Member: 169579 Status: Offline Thanks Meter: 10 | error on unlock 6288 spansion - cant unlock, need help! //start of log Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_ _Nokia IMEI: 353************ SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_353************_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_ _Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_353************_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_ _Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect test points Test points connected OK Keep Test points connected until unlock finish! Unlocking phone ... ERROR: 20030001 ERROR: 30020082 ERROR: 20040001 //end of log appreciate any help. Last edited by ktele; 01-11-2008 at 09:13. |
01-11-2008, 14:06 | #2 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
01-11-2008, 23:25 | #3 (permalink) | |
Member: 169579 Status: Offline Thanks Meter: 10 | Quote:
Hear from you soon. | |
01-14-2008, 07:22 | #6 (permalink) | |
//6280 info read by MT-Box Phone is in: Local mode Model: RM-78 ( 6280/6288) V 05.92/07-09-06/RM-78 Nokia Production serial number CRB953616 Product code 0542172 Module code Basic production code 0540642 Flash code Order number Long production SN MCU SW V 05.92/07-09-06/RM-78/ Nokia HW 2009 PCI RFIC 17211721 DSP pb05w46v31 LCD SHARP PPM V 05.92/07-09-06/RM-78/ Nokia/T Retu 32 Tahvo 53 Content Pack {Content: 3_au} { V 05.92 } 07-11-06 { Nokia}/ IMEI: 35************ hope this log will help to identify it and hopefully someone out there with a kind heart to assist. question: 1. whats different of ASK and RPL files? 2. how they (ask/rpl) are used to fix this phone? 3. can someone share suitable file for rpl write to this 6280 pls? info: currently when sim card is inserted, phone dont detect it. just give me a hint how to solve this problem pls. BR ktele for my secretary | |
01-17-2008, 13:39 | #10 (permalink) |
Insane Poster Join Date: May 2006
Member: 281005 Status: Offline Thanks Meter: 2 | i have error in creating pm308 backup, when I click on UNLOCK ********************************************** Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: *************** SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes ERROR: 11200001 ERROR: 30020033 ************************** any idea how to sort out this problem please |
s400I cant unlok need help | ERIC888 | UST Pro II | 7 | 03-08-2008 12:02 |
6280 6288 i cant unlock | elwardidi12 | BB5BOX | 14 | 01-04-2008 21:19 |
6280 and 6288 spansion not unlock after 20 try | ciavatta | BB5BOX | 7 | 12-06-2007 18:20 |
6288 unloking problem urgent need help | master10 | Nokia Base Band 5 ( BB-5 ) | 2 | 10-27-2007 18:20 |
p900 down screen cant touch need help | tony84 | Sony Ericsson Hardware Repair | 1 | 10-27-2005 13:46 |
