01-10-2008, 22:45 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: iPhone1,1_2.1_5F136
Member: 572149 Status: Offline Thanks Meter: 17 | E65 and 6131 unlocked succesfull Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 353261019134106 SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42501F Block 3: CLOSED Type 5 Data: 42510F Block 4: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-208_353261019134106_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250100000000000 Block 1: OPEN Type 5 Data: 42501F Block 2: OPEN Type 5 Data: 42501F Block 3: OPEN Type 5 Data: 42510F Block 4: OPEN Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull ------ Operation: UNLOCK Date: 10-01-2008 Time: 15:06:48 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 352257010903383 SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-115_352257010903383_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250100000000000 Block 1: OPEN Type 5 Data: 42501F Block 2: OPEN Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull ashraf azouqa jenin palestion 0599 105334 |
E65 and 6085 Unlock TP | MeeM | J.A.F. By Jafsupport.com | 1 | 02-05-2008 00:47 |
E65 unlocked succesfull | adriano II | BB5BOX | 1 | 01-05-2008 19:08 |
E65 Phone unlocked succesfull | toto2648 | BB5BOX | 7 | 12-30-2007 17:46 |
E65 and 6288 unlocked succesfull all Ok | azouqa | BB5BOX | 0 | 12-25-2007 16:04 |
6131 unlocked succesfull bb5box good | SGHGSM 3 | BB5BOX | 8 | 10-16-2007 16:52 |
