11-10-2008, 23:11 | #1 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16943 Status: Offline Thanks Meter: 35 | n95 unlock help i have one n95 (my first one) for unlocking but allways i have this error: Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface i have tested the cable in one 5200 and is working perfect, the miniusb phone conector is good, i don't know what to do, can anybody help me? thanks |
11-10-2008, 23:34 | #2 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Location, Location Age: 53
Member: 48886 Status: Offline Thanks Meter: 97 | Quote:
11-11-2008, 12:56 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | after u push switch on botton, wait a little till phone enter in test mode, this take sometime, and soft will not detect phone just wait ~8 sec and click phone info. Do not forget to disconnect lcd and camera. I unlocked today 2 pcs, and 100/100 Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 500 miliseconds Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2140100000000000 Block 1: OPEN Type 5 Data: 21401F Block 2: OPEN Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull BR, |
11-12-2008, 20:23 | #6 (permalink) |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 14047 Status: Offline Thanks Meter: 166 | make shore you cable correctly connected to fone with red vcc and yellow bsi on righ batt connectors and if fone is now detected as said by dust4dust use nokia charger or you may loose coneection |
The Following User Says Thank You to simlock For This Useful Post: |
n95 unlock help.... | .:Gsm-Nikki:. | Nokia Base Band 5 ( BB-5 ) | 2 | 05-02-2009 19:59 |
Nokia N95 unlocking... help me make a great christmas present please! | Richdog | Phone Unlocking Codes & Maps | 4 | 12-11-2007 19:11 |
n95 urgnt help need to unlock | great4nara | MT-BOX | 11 | 07-30-2007 08:10 |
my n95 unlock plz help | amar181 | Nokia Base Band 5 ( BB-5 ) | 1 | 07-29-2007 16:49 |
N95 unlock by imei!HELP ME !! | nazarevich | Nokia Base Band 5 ( BB-5 ) | 12 | 07-14-2007 13:37 |
