help unlock n95 Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v50.2_28-01-08_RM-159_(c)_Nokia IMEI: 353094028571574 SP LOCK status: Config Key: 2082000000000000 Block 1: CLOSED Type 5 Data: 20820F Block 2: CLOSED Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 ERROR: 11180001 ERROR: 30020031 |
It is because the cell was shut down ..... Disconnect the camera and try again, if the error persists I suggest you use the power adapter. |
Completley strip the phone down to the Board, use Ground on Vibe motor. |
conect nokia charger to bb5 box then try also remember to remove it after as this may couse damage to other fones if you dont |
