Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 11-12-2008, 13:41   #1 (permalink)
Member: 610806
help unlock n95
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-159
Version: V_06wk41v50.2_28-01-08_RM-159_(c)_Nokia
IMEI: 353094028571574
SP LOCK status:
Config Key: 2082000000000000
Block 1: CLOSED Type 5 Data: 20820F
Block 2: CLOSED Type 5 Data: 20820F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Create autobackup of PM 308
ERROR: 11180001
ERROR: 30020031
Old 11-12-2008, 14:45   #2 (permalink)
Member: 679135
Sonork: 100.1606448
Type: RM-159
SP LOCK status:
Reset phone ...
ERROR: 11180001
ERROR: 30020031
It is because the cell was shut down ..... Disconnect the camera and try again, if the error persists I suggest you use the power adapter.
The Following User Says Thank You to hvalero2001 For This Useful Post:
Old 11-12-2008, 18:29   #3 (permalink)
Member: 600824
Completley strip the phone down to the Board,
use Ground on Vibe motor.
Old 11-12-2008, 19:24   #4 (permalink)
simlock's Avatar
Member: 14047
conect nokia charger to bb5 box then try also remember to remove it after as this may couse damage to other fones if you dont
Help unlock N95 Orange paulosilva1979 Nokia Base Band 5 ( BB-5 ) 1 06-23-2009 14:05
help unlock N95 8GB v59.01 izamer Nokia Base Band 5 ( BB-5 ) 17 04-22-2009 18:55
help Unlock N95 RM-159 Audsky Basic Micro-Box Software Support 1 02-02-2009 06:05
help unlock n95 8gb sweden 3 danjarz1 Nokia Base Band 5 ( BB-5 ) 1 01-18-2008 21:39
Page generated in 0.26979 seconds with 11 queries
