02-15-2008, 02:50 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: UnLoCkGsM-Bogota
Member: 543296 Status: Offline Sonork: 1653004 Thanks Meter: 44 | How Repair Config Key Of Nokia 6131?????????? Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 35977000451***X Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_05.50_20-09-06_RM-115_(c)_Nokia. IMEI: 35977000451***X SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-115_35977000451***X_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Unlock fail. Please try again. HELP ME |
**FREE** How to repair config key "000000000" with JAF>>>SL2/SL3 **FREE** without RPL | B Smith | Nokia Base Band 5 ( BB-5 ) | 891 | 07-25-2011 14:24 |
2/9/9 FREE How to repair config key "000000000" with JAF>SL2/SL3 (FREE) without RPL | golden_gsm | Nokia Base Band 5 ( BB-5 ) | 16 | 09-03-2009 06:06 |
how to repair Config Key | Parminder Singh | BB5KING | 2 | 12-16-2008 12:14 |
