10-19-2007, 03:06 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 58
Member: 178483 Status: Offline Thanks Meter: 4 | How to unlock Soft Bank 705NK(N73) Thanks |
10-19-2007, 03:23 | #2 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Philippines Age: 47
Member: 4873 Status: Offline Thanks Meter: 5 | check for compatible version here: http://forum.gsmhosting.com/vbb/showthread.php?t=443576 use tp for unlock. Read the manual to avoid dead phones. B.R. |
10-19-2007, 04:18 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Philippines
Member: 252201 Status: Offline Thanks Meter: 148 | Another N73 SOFTBANK UNLOCKED IN 60 MIN. REAL TIME.. NOT BAD.. Another N73 softbank pink color unlocked in 60 min real time. All setup, upgrade flash, disassemble, setup with tp mic. and reassemble.. Improved before 2hrs. Here is the logs. ------ Operation: READ PHONE INFO Date: 18-10-2007 Time: 11:38:08 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-67 Version: V_05wk33v23.5_04-04-06_RM-67_(c)_Nokia. IMEI: 357941000610182 SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries ------ Operation: READ PM 308 Date: 18-10-2007 Time: 11:39:08 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-67 Version: V_05wk33v23.5_04-04-06_RM-67_(c)_Nokia. IMEI: 357941000610182 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 4096 bytes Saving to file: RM-67_357941000610182_Locked_Keycnt_0_Fbuscnt_0__V_05 wk33v23.5_04-04-06_RM-67_(c)_Nokia.__18_10_2007__11_39_15.bin ------ Operation: UNLOCK Date: 19-10-2007 Time: 10:19:11 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v48.3_02-07-07_RM-133_(c)_Nokia. IMEI: 353641019376312 SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_353641019376312_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v48.3_02-07-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! ------ Operation: UNLOCK Date: 19-10-2007 Time: 10:20:55 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v48.3_02-07-07_RM-133_(c)_Nokia. IMEI: 353641019376312 SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_353641019376312_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v48.3_02-07-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4402000000000000 Block 1: OPEN Type 5 Data: 44020F Block 2: OPEN Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-19-2007, 16:27 | #4 (permalink) |
Member: 178483 Status: Offline Thanks Meter: 4 | I tryed unlock. but error. please help. ------ Operation: READ PHONE INFO Date: 20-10-2007 Time: 00:01:51 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v39_30-11-06_RM-133_(c)_Nokia. IMEI: 351851016412521 SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries ------ Operation: UNLOCK Date: 20-10-2007 Time: 00:01:56 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v39_30-11-06_RM-133_(c)_Nokia. IMEI: 351851016412521 SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-133_351851016412521_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v39_30-11-06_RM-133_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-133_351851016412521_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v39_30-11-06_RM-133_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... ERROR: Not suported model/version ------ Operation: UNLOCK Date: 20-10-2007 Time: 00:04:12 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v39_30-11-06_RM-133_(c)_Nokia. IMEI: 351851016412521 SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_351851016412521_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v39_30-11-06_RM-133_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-133_351851016412521_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v39_30-11-06_RM-133_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... ERROR: Not suported model/version |
10-30-2007, 21:02 | #5 (permalink) | |
Freak Poster Join Date: Jul 2001 Location: Portugal
Member: 5287 Status: Offline Thanks Meter: 16 | Quote:
you have to flash to another version! | |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
Post succesfuly unlock soft bank with USTpro here | sarfraz | UST Pro II | 1 | 09-16-2011 13:35 |
how to unlock iphone 3.0 | louisgsm | iPhone 2 / iPhone 3G / iPhone 3GS | 10 | 03-29-2010 15:53 |
how can unlock soft bank 705pxx | askaralikp | SPT BOX | 2 | 03-21-2009 23:51 |
