11-17-2007, 22:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: On Roads... Age: 43
Member: 107839 Status: Offline Sonork: 100.1592822 Thanks Meter: 70 | I think V.027 is little buggy Log inside Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 353262010486479 SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42501F Block 3: CLOSED Type 5 Data: 42510F Block 4: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Skip autobackup of PM 308 Autobackup file: RM-208_353262010486479_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. With V026 - unlocked (5 sec-no microscope) first try: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 353262010486479 SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42501F Block 3: CLOSED Type 5 Data: 42510F Block 4: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-208_353262010486479_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-208_353262010486479_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42501F Block 3: CLOSED Type 5 Data: 42510F Block 4: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250100000000000 Block 1: OPEN Type 5 Data: 42501F Block 2: OPEN Type 5 Data: 42501F Block 3: OPEN Type 5 Data: 42510F Block 4: OPEN Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull P.S also there is problem with GUI in thema settings - it's always stay at windows - even if u change to orange. B.R ZACHI |
11-18-2007, 10:01 | #3 (permalink) | |
Freak Poster Join Date: Feb 2003 Location: ALGERIA Age: 43
Member: 20726 Status: Offline Thanks Meter: 19 | Quote:
dide you update box fw after using V027(update box is recured) and good luck | |
11-18-2007, 10:19 | #4 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | this problem occur always on unlocking 6280 i have never unlocked this type, i do not know what is wrong after all connection of tp is ok when i unlock i got lost link, i purchased new tp from i-pmart i cannot use it because there is no lebel of which colour we have to connect to clk and data, if i will get the collect colour for data this is very good test point there is no lost link, no shork distance like tp comming with the box no press button which is very dengerous that you can destroy the cpu ball |
11-18-2007, 11:05 | #5 (permalink) | |
Member: 107839 Status: Offline Sonork: 100.1592822 Thanks Meter: 70 | Quote:
Just found small trick for 6280 - connect TP press unlock & release DATA TP - when u see program send codes touch again quickly - phone will be unlocked - i think it's bug. B.R ZACHI | |
z300 dont work - log inside 9.71 | hridaya | Cruiser Suite | 4 | 12-04-2006 04:54 |
