Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 03-24-2008, 21:04   #1 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 301
5300b V_05.51_05-09-07_RM-147 cant be unlock by bb5 box
hi support
its my 1st phone that cant be unlock wiz bb5box...
any 1 can help me to solve this.........
phone version was v 5.10 (not support)
i upgrade to 5.51.
thnx bb5box team
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-147
Version: V_05.51_05-09-07_RM-147_(c)_Nokia.
IMEI: 352732017719461
SP LOCK status:
Config Key: 3027200000000000
Block 1: CLOSED Type 5 Data: 302720
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Skip autobackup of PM 308
Autobackup file:
RM-147_352732017719461_Locked_Keycnt_3_Fbuscnt_10__V_ 05.51_05-09-07_RM-147_(c)_Nokia..bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest counters ...
Finded backup file: RM-147_352732017719461_Locked_Keycnt_0_Fbuscnt_0__V_0 5.51_05-09-07_RM-147_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Delaying unlock procedure with 1000 miliseconds
Try unlocking using keyboard codes ...
Try number (Keyboard): 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number (Keyboard): 2
Response byte: 08
Try number (Keyboard): 3
Response byte: 08
Unlock using keyboard codes fail.
Try unlocking using cable codes ...
Try number (Cable): 1
Response byte: 08
Try number (Cable): 2
Response byte: 08
Try number (Cable): 3
Response byte: 08
Try number (Cable): 4
Response byte: 08
Try number (Cable): 5
Response byte: 08
Try number (Cable): 6
Response byte: 08
Try number (Cable): 7
Response byte: 08
Try number (Cable): 8
Response byte: 08
Try number (Cable): 9
Response byte: 08
Try number (Cable): 10
Response byte: 08
Unlock using cable codes fail.
Reading again SP Locks ...
SP LOCK status:
Unlock fail. Please try again.
Old 03-24-2008, 21:08   #2 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 301
i try many time, change grnd, smtime got response bytes 55, but no unlock!!!!!!!!!!!!!!!
Old 03-24-2008, 21:38   #3 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
ur all counters is full u cannot rest counter in bb5box use other box for reset
Old 03-24-2008, 22:04   #4 (permalink)
nost's Avatar
Member: 197360
Thanks Meter: 25
it happens, you must restore pm and try again and again, it will unlock
Old 04-03-2008, 23:22   #5 (permalink)
Member: 169095
Thanks Meter: 5
same problem i have no unlock try and try any help
Old 04-04-2008, 00:03   #6 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
try change connection of clk and data...some cables come with reversed colors...that if u r not sure where is data and clk
if u already used this cable and unlocked before other phone than change gnd place
try to connect data and gnd...press unlock and when asked to connect test point connect clk
Old 04-09-2008, 14:35   #7 (permalink)
Member: 481337
Thanks Meter: 6
Just move the GND on the opposite side than shown on the TP picture.
I failed to unlock 5300b 10 times with the GND shown on the picture, but after moving it to the opposite side it unlocked immediately.
Good luck!
Old 04-09-2008, 18:00   #8 (permalink)
enzawigroup's Avatar
Member: 141363
Sonork: 100.1594362
Thanks Meter: 148
u need to right bkup
Old 04-09-2008, 18:06   #9 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 301
right backup ok, but in vain
i upgrade and unlock it on 1st try
how to xplain this Mr raskal
why i can see this version supported on ur page, but i need to upgrade
Old 04-09-2008, 18:48   #10 (permalink)
Member: 180091
Thanks Meter: 62
this is very simple my friend ,i have the same problem before but was solved.this is the solution, on the GUI option, change it from windows to orange and the phone will unlock on first atempt. Good Luck
Adebam
Old 04-10-2008, 15:08   #11 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
think that sometimes we have to upgrade/downgrade to rebuild sp area, so unlock procedure goes better.
it s not becoz ver not supported but becoz of sp area hav to be rebuilt.
nokia 6124c-1 rm-422 by vodafone cant be unlocked by mxkey (ANSWERED) med26 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 07-17-2011 21:37
X650 Cant Be Unlock By Hwk Why? denard HWK 3 10-10-2009 05:14
5300b t-mobile success unlock by bb5 box GUDO-GSM BB5BOX 0 10-24-2007 11:06
6085 can't be unlock by BB5 box ! hatali BB5BOX 4 10-12-2007 11:59
V220 cant be unlocked by v2.09? a4tech Smart-Clip 9 04-12-2005 17:30
Page generated in 0.19291 seconds with 9 queries
